Question about Bosch 1617EVS 2 Router
Plunge mechanism on bosch router stuck - Bosch 1617EVS 2 Router
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Bosch 1613 vs router, plunge does not stay locked
It looks like according to the breakdown that there is a hex head bolt under the release lever that when removed can be tightened some to keep it from moving. Before removing anything when you lock it are you putting some pressure on the lock handle. I have one at work that I have to push some on to snug it. If so I would recommend going to Boschtools.com and typing in your exact model number and it will take you to a page where you can look at all the parts involved (about 4) but the operators manual doesn't tell me a thing about agjustments.
Posted on May 18, 2009
comax
  • 154 Answers
SOURCE: how to attach 'plunge lock lever' to Bosch 1617
I have been repairing the Bosch tools for quite a few years and I still hate putting those levers on. Unfortunatly,there are no "tricks", you just have to set the spring in the lever then use a small screw driver to set the other end in its slot. Then try to rotate the whole thing untill the lever goes into the proper notch. It usually takes me 5 or 6 times to get it in, sometimes it goes in first time (rare). Sometimes I'm at it for 1/2 an hour.
Good Luck
Posted on Feb 11, 2010
I have lost user manual for pof 500a router, do you have any info please
Hi pf,
Go to this site and enter your model number and download a free version.
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx#
Handie Andie
Mar 21, 2011 | Bosch Plunge Router
Need a manual for router 1617 EVSPK.
All the manuals for the Bosch tools can be found on Boschtools.com, there is an area on the website that says "owners manuals".
Jan 09, 2011 | Bosch Plunge Router
Plunge router is stuck in the router base. Porter Cabe 891 router is stuck in the plunge base. Released the buckle and won't come out. What to do? Thanks, Joe
If you are talking about the nut tap on it with a hammer, if you are talking about the tubes you can try cleaning them with air and then using some lubricating fluid to free up the piston/springs. Let me know if you need more help
Mar 15, 2010 | Porter Cable-Cable 891 2 1/4 Peak HP...
I need a 7/16 (12mm) template guide for a bosch POF 1200 AE router. Where do I get one? Regards Paul.
various tool shops. try www.axminster.co.uk or www.rutlands.co.uk both are good tool suppliers with a good range of parts
Jan 30, 2010 | Bosch Plunge Router
How to attach 'plunge lock lever' to Bosch 1617 EVS router. I had this router replaced because of corrosion, when I opened the case the lever was detached from plunger. Tricky to attach, any suggestions
Good Luck
Oct 24, 2009 | Bosch 1617EVS 2 Router
Bosch 1613 vs router, plunge does not stay locked how do I fix it?
May 16, 2009 | Bosch 2610997137 Na Deluxe Router Guide...
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Jan 01, 2009 | Bosch Plunge Router
1613EVS Plunge Router will not operate. Does not start !
hello- had same problem with similar model-- problem is definitely DUST INSIDE THE SWITCH, it must be blown out with compressed air- i had this done at a repair shop (for free) so i don't know if they had to disassemble anything- hope this is helpful
john
Nov 16, 2008 | Bosch Plunge Router
Horespower Question
A 2-horsepower motor is good for most people. A larger one is needed for professional work; while an even smaller motor is good for detail work.
Aug 27, 2008 | Bosch Plunge Router
Bosh Router 1613evs
Go to this web address and that will tell you how to fix your problem.
http://www.ereplacementparts.com/bosch-1613evs734-0601613734-plunge-router-parts-c-128_1119_1127.html?sort=5a&page=1
Hope This Helps
All The Best,
RCF
May 10, 2008 | Computers & Internet
Bosch 1617EVS 2 Router Logo
81 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Tom Chichester
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
