Fisher and Paykel IWL12 Top Load Washer Logo
Posted on Nov 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine not spining
Hi my washing machine was working fine yesterday.
This morning themachine started to beep constantly and advised of error and service 37 required.
The machine is pumping water but will not spin!
When I progress the machine to first rinse cycle the water flows but no spin. then it progresses by itself to second rinse but will not spin and finish. what happens instead it goes back to first rinse cycle for 20 mins then second for 9 mins ( every time I open lid time resets for spin cycle.)
Anonymous
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Nov 04, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
146
Questions
Helped
100727
Points
223
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
Glws1339csi is not washing
Good Morning Friend,
I understand your Frigidaire washer, model#GLWS1339CSI, will not wash your clothes. I also see that it will spin. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Kenmore washing machine big troubles?
Please list the model number of that machine. IT could be made by several manufacturers for Sears.
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Constant beeping while washing
This can be due to fault within the control panel output to the indication and buzzer. If the washer works without any issue and the cycles are correct, then it is best to remove the buzzer connections as the drive output transistor or IC could be intermittent and so works erratic.
2answers
Indeset washing machine has stopped working. You select the programme the green light comes on but nothing happens. It in not filling up/ draining/ spining nothin, Can you help????
this may sound silly but just had the same problem changed the pump and it works fine now, if the pump does not work it wont let the washer start
Hi, My washing machine, Fisher and Paykel, MW 511 PRIDE would not do the SPIN cycles. Please advise. Thanks. Sam Lee
Hi Sam Lee.Now , does the machine drain the water?If it does drain the water does it stop and beep and show an error code?if it does the error code will be a series of lights that will light up when the machine is beeping.They will be on a row of 8 lights.Starting from left to right which lights are lit when the machine beeps,Is it the 2nd and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
1helpful
2answers
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
