Question about Teac Audio Players & Recorders
Teac AG v6200 wont stay on
Turn on sith switch stays on 3 or 4 seconds and turns off stand by light blinks
  • braines2 Jun 23, 2009
    Is this problem fixable for layman or does this require tech person?
    New Friend:
Check your speaker wires, if they are crossed somewhere then the system protects it's self.
Posted on Nov 15, 2012
  • zacharyschul
    zacharyschul Nov 15, 2012
  • Jason Richardson
    Jason Richardson Mar 11, 2018
    I have the same unit with the same problem and I don't have any speakers connected.
Will not switch on
Probably an electrolytic capacitor blew... should be obvious if you remove the case. The tops blow off or split... may leave residue.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Red light blinks and wont stay on when push power button
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
My TEAC AG-7D turns on for about a second but then turns off
There is a problem in the final stages of the amplifier section that the protection circuits are detecting. They then shutdown the unit to prevent further damage. The most likely candidates are the output transistors. This is a relatively simple repair for an audio shop. Expect a parts cost between $20-$45.
Dan
Jul 15, 2009 | Teac Audio Players & Recorders
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Lost manuel for teac ag d9100 reciever
you can download a manual for $9.99 from User-Manuals.com....I did this today and the manual is identical to the original it seems
Jul 11, 2008 | Teac AG-D9100 Receiver
975 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
