Question about KitchenAid Kitchen Ranges
What is the cost of kitchen aid masterboard - KitchenAid Kitchen Ranges
Broken magnet of a Kitchen Aid Blender. Where can I find another one? KSB5WH4
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
Apr 26, 2016 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Kitchen aid mixer on but spining.
not sure that I understand. the mixer is on and spinning or it is on and not spinning. if it is not spinning it is a gear problem and takes about 2 hours to do and cost about 25 dollars. send us some more info and we can help.
Aug 11, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid stand mixer head doesn't lock down and wobbles
You need to do a couple of strokes with a rat tail file at a 30 degree angle at the top of the slot the head lock engages into. You will need to remove the hinge pin to do this. A Kitchen Aid agent will have done plenty of then so it won't cost an arm and a leg to get it sorted.
Nov 17, 2012 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid Mixer
good day,
hope this link below will solve your problem.
kitchen appliances
Apr 08, 2009 | KitchenAid KP2671 Professional 6 Series...
I have a kitchen aid flat stove top. The glass on
I don't know who can change one there but I know the tops for those unit run between 350.00 and 500.00 just for the top have you tried cleaning with a razer blade like creaning the paint off glass it works great
Mar 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Classic mixer
There are 2 possibilities, the attachments are worn out where they go on the shaft, simply replacing them could fix it, the other is the shaft is worn out inside the planetary ( where it spins), if it moves allot, 1/8 " or more from side to side, the housing is probably worn, and the planetary needs to be replaced, easy job, don't know cost, a new mixer may be in order.
Dec 26, 2008 | KitchenAid K45SS Classic Stand Mixer
Window to my oven door is broken
No...that's only if you go through chat sessions. I don't charge to give people advice.
Jan 25, 2008 | Kitchen Ranges
Can't attach beater to kitchen aid
good day,
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Open Questions:
Kitchen Ranges Logo
81 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
