Iconcepts usb to serial adaptor will not function
New mouse does not work.
How does it Connect to your Computer? Probably has a USB Drive that you are suppose to plug in
Try turning your Batteries around (My Microsoft Mouse had the same issue and when I turned it around, everything started to work...
Apr 11, 2013 | Sakar Iconcepts Iconcept M01728 Wireless...
Mouse
Turn the Batteries Around and see if the Red Light on the Bottom comes on
I have an Sam4 ER600 which is 9 pin seriel and only USB on my computer. I have got the recommended adaptor and software but my computer still doesn't recognise it... It says port failure. Can someone...
Buy an Athen usb-->Rs232 adaptor and install the program.. then go to hardware settings and set that usb port to Serial port 1 (very important)
After that you just start the program, opens your store @ port 1 and programs..
Jul 27, 2010 | Samsung Computers & Internet
Need software to connect GP31 via serial to USB cable to W7 PC
Make sure you installed the driver for the serial to USB adaptor cable.
Jun 30, 2010 | Furuno GP31 GPS Receiver
I have purchased a Nextar Bluetooth Solar Charging wireless speaker from Kohls Department Store in Sussex WI I paid $99.00 serial number is VT0906005834 and it was manufctured June 2009. I bought it on Jan...
Please use the car adaptor and/or USB adaptor(Car adaptor is equipped with USB adaptor as well) to charge the unit. Car adaptor will be fast and effective as compared with USB, USB charging thru PC is slow.
Try this.
Feb 08, 2010 | Cell Phones
Tried using usb to seriel adaptor but unable to read while reading 2way radio software. pretty sure its between the usb/adaptor
make sure that both the cable and the software that you are using are set to same Com ports.
Ex. the cable set to Com4, the software must be set to Com 4
To change the Com ports of the cable you just got to Device Manager under System Properties then on the properties of the serial cable there is an option to change the Com port settings.
To change the Com port setting of the software just simply go to its settings or preferences.
Jun 16, 2009 | Belkin USB/Serial Portable Adapter...
GPSmap 176 not communicating with laptop via serial/USB adaptor
sounds you do not have appropriate usb driver so find download and install usb driver from following website:
http://www.usb-drivers.com/
chose your compute product to make sure about USB driver.
Nov 11, 2008 | Televison & Video
Belkin USB/adaptor
Google Franson GPS GATE this little software utility is what you need
Mar 31, 2007 | Belkin USB/Serial Portable Adapter...
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
