Question about Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System
How to setup answering - Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
What model Panasonic DECT 6.0 system?
Posted on May 12, 2014
How do I setup a Uniden Dect 5.8Ghz 8155+2 phone
Uniden XDECT 8155 + 2 Questions & Answers ...
www.productreview.com.au > ... > Uniden > Uniden XDECT 81xx Series
Uniden XDECT 8155 + 2: 25 questions and 38 answers on Australia's largest opinion ...and select Handset Setup or Base Setup. ... If you have a 2.4 ghz or 5.8 ghz modelphone use web address below. .... Uniden Premium DECT 31xx Series.
Nov 23, 2015 | Uniden Lands Phones
Tip
How to do Fast and unattended setup of OS
Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement. Verify for unattended Installation: To perform an unattended installation from a CD-ROM, the following conditions must be met:The computer must support booting from a CD Rom The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.The answer file must contain a valid [Data] section. This is explained later in this article. Before installation it has some conditions:
1> the installation is limited to a single partition.
2> you cannot specify third-party drivers during Setup Prepare For an Unattended Installation:
To prepare your computer for an unattended installation from a CD-ROM, I've followed these stepsFirst I've created a Folder in local drive & shared it. Then I create setup manager.I install Setup Manager by following these steps:I Open My Computer, and then open the SupportTools folder on the Windows XP CD-ROM.Double-click the DEPLOY.CAB file to open it On the Edit menu, click Select All.On the Edit menu, click Copy to Folder.Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.Click Copy. Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows
Setup Manager Wizard starts: alokerdas_2.jpg
Then I Use Setup Manager to Create an Answer File.
I open the setup manager & go to create a new answer file.
Then I go to the unattended installation & windows version option.
I have selected the fully automated option & create an answer file.
If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"
If you omit this line, you are prompted for the installation partition.
Add a [Data] section with the following entries to the unattended answer file:
Unattended Install=Yes - Value must be set to "yes"
MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup
Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.
Save the unattended answer file as Winnt.sif on a floppy disk.
Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.
Change the boot order in the CMOS so that the CD-ROM is first in the list.
Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.
<SPAN style="FONT-FAMILY: 'Courier New
on Feb 15, 2011 | Computers & Internet
I can't find the auto answer light on the Lexmark X6675
To turn on the Auto Answer for fax, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering > Auto Answer > On.
Sep 10, 2012 | Lexmark X6675 All-In-One InkJet Printer
How can I set up my answering machine with my hp 2140 fax
Use the fax setup wizard from the HP toolbox , when it asks if you have an answering machine connected to the fax line say yes. Or setup a distinctive ring from you phone company and set the fax machine to answer double rings only. Use fax setup wizard to do this as well.
Jun 14, 2011 | HEWLETT-PACKARD HP 2140 Fax
How to get my s405 to receive a fax
You might want to check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > Pro200 Series > User's Guide. Go to page 62 to know how to setup your printer to fax.
If your fax is already setup - meaning you're already able to send faxes but not able to receive. Make sure that the Auto Answer is on. To check that, on the control panel of your printer, press on Setup > Fax Setup > Auto Answer.
If you have an answering machine, make sure that your fax will pick up 3 rings higher that your answering machine. If you answering machine picks up on the 5th ring, set your fax to pick up on the 8th ring. You can change that under fax setup.
If you have a voice mail service enabled in your phone, you'll need a distinctive ring feature for your fax to work if it's being shared on the same line.
May 23, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
My answering maching is answering in another language. How do I get it to answer in english?
Press and release SETUP button until you hear the feature announced that you want to change.
Press ANNC/SKIP or MEMO/REPEAT button to change the current setting. Press PLAY/STOP to
exit feature setup.
Jan 19, 2011 | AT&T 1717 Digital Answering Machine
My hp color laserjet 2320 printer when i receive fax 6 times ringing i want make it 1ring
Set the number of rings-to-answer To set or change the number of rings-to-answer, use the following steps:
  1. On the control panel, press Setup .
  2. Use the arrow buttons to select Fax setup , and then press OK .
  3. Use the arrow buttons to select Basic setup , and then press OK .
  4. Use the arrow buttons to select Rings to answer , and then press OK .
  5. Use the up and down arrows to enter the number of rings-to-answer (1 or 2), then press OK .
All Done! Good luck!
Nov 29, 2010 | Home
Setup answering mach.
how do you set up the answering machine on the base?
Feb 14, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System Logo
53 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
