Question about Sunbeam Cafe EM6910
Em6910 collar replace
Replace group head collar
    Filmmaker:
    Uploaded 5 video answers.
  • 39 Answers
The whole collar or do you just mean the blue silicone seal?
You can buy the blue seal on eBay. Simply undo the Philips screw in the centre of the 'shower' in the group head, take out the two shower screens and the blue seal will be fairly easy to remove.
Posted on Aug 12, 2014
EM6910- I was cleaning the group head area with the water out and the machine on it's back.When I stood it up the pump started and wouldn't stop. No response from any buttons. Any ideas?
First, I'm not a Sunbeam Tech.
Call your MFR or vendor for service. Especially if this equipment is on loan.
*** Following is for information only.***
* There usually an internal tank (boiler) in this type of brewer. Water may have leaked on to the control board. Call for service.
* Vibration pump comes on when powered up. It fills the inner tank boiler till the water level probe senses the tank is full.
* Water level probe is out of place or more likely the wire to the probe came off. It may look like a nail with a flat head that connects to a singe wire.
* Make sure there is no water around the boiler. Better that everything id completely dry prior to power application.
* There are really no customer serviceable parts (other than cleaning and lubrication.)
* check youtube for more information.
Aloha, ukeboy57
PS: FYI, I found this on line;
https://www.manualslib.com/manual/935016/Sunbeam-Em6910.html?page=9#manual
Feb 21, 2018 | Coffee Makers & Espresso Machines
Pressure valve
Generally, this is not a problem with the machine but with how you're loading the coffee! Sounds typical of one of these problems:-
Not enough coffee in the basket
Coffee should be filled and tamped to about 3mm below the rim.
Coffee grind not fine enough (too coarse)
Do you grind your own coffee or buy ready-ground? If buying ready-ground, make sure it is for espresso (fine) and not for filter or plunger.
If you have your own grinder, (like the Sunbeam Conical Grinder), then make sure the coffee hopper on top is securely connected to the grinder. I'd been using mine for years on the the finest grind (1) not realising the hopper wan't on right. Only discovered it when I took it apart to clean. Now my grinder is on 9-10 to grind for espresso.
Coffee not tampered down hard enough
You do need to provide a reasonable degree of pressure to tamp he coffee down just right.
Group head not turned tight enough
Push the group handle as far to the right as it will go, then ease it back just a fraction to have the right pressure.
Jun 22, 2014 | Sunbeam Cafe EM6910
Why has my guage stopped working?
You have a blockage in the system and the group head will be full of coffee fines and oils. Needs a full service
Apr 25, 2014 | Sunbeam Cafe EM6910
Sunbeam EM6910 coffee machine .No power or lights
It's most likely the main fuse. Google "replace EM6910 fuse" and you'll find an easy guide.
Apr 09, 2014 | Sunbeam Cafe EM6910
No water coming through
Depending on if this is HW or Group water... But if you did not clean teh shower screen and group first; you have loosened scale and it is caught in the HW change over valve.
Mar 20, 2014 | Sunbeam Cafe EM6910
Service manual
Perform a full descale. Take out the water reservoir and remove the Anti-calc filter. Put in 500ml (1 pint) water with 3-4 tablespoons of white vinegar (or apple cider vinegar). Put the water canister back in, the turn on the machine and press the manual button. Allow half of the liquid to go through, then stop. Leave the machine for about ten minutes, and then run the rest through. Empty the water reservoir and rinse, put back the Anti-Calc filter, put in another 500ml and press the manual button to flush it all through.
Jun 18, 2013 | Sunbeam Cafe EM6910
How to change shower headplates and seal on EM6910
Shower headplates should never need replacing. If they get clogged, pop them in a bowl, our vinegar over them and leave them for 10 minutes.
Dec 16, 2012 | Sunbeam Cafe EM6910
Are martingale collars good for all types of dogs?
Although originally designed for greyhounds and whippets, many dogs can be trained on this type of collar. It works well on dogs with necks larger than their heads - such as bulldogs.
Jul 19, 2012 | Pets - Others
The exhaust on my rear cylinder is making excessive noise, i'm not complaining but on inspection, the manifold is split, it seems to have made out of 2 pieces! why would any1 do that??? shoud i replace...
Muffler putty, no. If you have it off, take it to the local welder. They can tell you if it is fixable. Usually your best bet is to just spend the money and order a new original equipment replacement part (if a good salvage/used part is not available. Be sure to replace the exhaust gasket in the head when you put the pipe back on. EBAY may be a good source of a good used head pipe.
Sep 27, 2011 | 2000 Suzuki VL 125 Intruder LC
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
Sunbeam Cafe EM6910 Logo
312 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
rhodesworks
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
