Eiki lc-xb24 projector cost to service ( outside warranty )
Projector not working as there has been a building up of dust. What is the projected cost for repair?
  • 2318 Answers
SOURCE: Bulb Life
The bulb should last for about 2500 hours as per the manufacturers.
Try resetting the timer even without replacing the light bulb. Check page # 49 of the PDF file on how is done.
http://www.aboutprojectors.com/pdf/eiki-lc-sd15-manual.pdf
I would suggest to turn the projector OFF when not in use.
Good Luck.
Posted on Feb 07, 2008
SOURCE: the projector switching off after 30 seconds
check the following :
1.does the lamp glow
2.do u get the connected image
3.if yes does the screen show temperature or overheat
4.if yes then one of the cooling fans do not work properly & hence the unit turns to standby & goes into protection
if no 1 does not happen, then check the lamp physically,it should not show melted or breakage.
if the lamp seems ok, then the ballast is defective!
Posted on Feb 08, 2009
  • 87 Answers
SOURCE: Our Eiki LC-986 projector has worked flawlessly
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Posted on Jun 15, 2009
RedZone133
  • 25 Answers
SOURCE: consistent flickering; had the projector on for 2
Check your filter and make sure the projector is well ventilated ( all vents free of objects), all electronics have to cool. Some lamps start flickering when their about to die.
Posted on Oct 27, 2009
projdoc
  • 2237 Answers
SOURCE: in few minutes after turn on the projector (Eiki Lc-xnb4m) ..
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Posted on Nov 18, 2009
Projects blurry picture onto screen even after adjusting the focus. It is an EIKI Diamond Projector LC-SD10.
Did you connect signal with native resolution 800*600
blurred picture can also be caused by extreme contamination of optical parts
Aug 22, 2011 | Eiki LC-SD10 Projector Multimedia...
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Laptop won't project onto Eiki
The signal type settings wrong in the menu, or broken interconnection between input board and mainboard of projector, due to shocks during portable use.
Jun 10, 2009 | Eiki LC-XB20 Projector Multimedia...
Display color problem, Eiki projector LC-NB2UW
Hi sjmuseum
If you cannot find the advanced option in the standard users menu , then it will only be in the Service Menu which you would have to call Eiki support to find out how to enter the Service Menu.
May 12, 2008 | Eiki LC NB2UW Multimedia Projector
EIKI LC-XG210
I t may be a dust or somebody before you tried to clean it and didn't make optical adjustement.Its very tricky to disasembly and if you want service manual conntact me at sanjinbosna@yahoo.com
Feb 16, 2008 | Eiki LC-XG210 Projector Multimedia...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
24 people viewed this question
jasbo
jasbo
