Question about GE (PSS26MSRSS) Side by Side Refrigerator
No water entering ice maker ge pss26 - GE (PSS26MSRSS) Side by Side Refrigerator
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: GE PSS26 NGP Ice maker
Hi Vadim, You should have a steady light showing on the ice maker. If the lead is flashing, it's either a thermistor failure or ejector not home. The reasons why the ejector blades will not home is because of a magnet failure, control board failure or a stalled motor. The feeler arm could also be sticking. The control board contains 2 sensors that are activated by magnets. One magnet is attached to the end of the ejector arm to determine whether the ejector blades are at home. The other is located on the ice sensing arm, lets the control know whether the arm has reached a fully extended position. In a lot of these, I find the magnets broken. I think you can save yourself a lot of trouble by just replacing this ice-maker. Catriver.
Posted on Dec 29, 2007
aasc
  • 1606 Answers
SOURCE: I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Posted on Jul 28, 2009
  • 180 Answers
SOURCE: ge ice maker wont make ice , no water entering
Take the front cover off of the ice maker.  Under the cover there are some test points,  V stands for valve and should have 120,  L stands for line and should have 120,  N is nuetral and should have continuity to ground. If all of these check good replace the ice maker, If not troubleshoot the wiring.  The fastest way to find out if it is the ice maker it to jumpre the two middle terminals on the ice maker plug.  If it spits out water replace the ice maker.
Posted on Oct 25, 2009
aasc
  • 1606 Answers
SOURCE: No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Posted on Jan 01, 2010
Thru the door water dispenser won't dispense water, but ice maker is working and making ice
That should be a simple fix providing you disconnect power and turn off the water supply. Your model being a PSS26 or what ever size GE still uses the basic partsin that full line or series. The part number for your dual water control valve is WR57X10040
Here is a link to the service manual for all that fall in your models series and styles=> http://appliancepartsseabreeze.com/appliancepartsseabreeze/manuals/Pss26MsRSS.pdf
Here is a link to my web site=>
sea_breeze_11.jpg Here is the location=> Page 17 in PDF
Here are some close up drawings of the wiring with test points Here=>
GE ARTICA PROFILE TECHNICAL INFORMATION
I will be here if you need help, Thanks, Sea Breeze
Dec 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge ice maker wont make ice , no water entering tray clynoid water valve ok.
Oct 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water inside bottom of freezer.
Water accumulation in the freezer more commonly points to the ice maker. Over a period of time, water entering the ice maker can slowly freeze to the point it provides a small restriction and prevents a portion of the water from entering the ice maker. The plastic spout/tube could also have either cracked or shifted and is allowing a small amount of water to leak into the freezer.
Feb 24, 2009 | GE GSS25SGPSS Side by Side Refrigerator
My ge icemaker will not fill with water. if i fill the tray it will freeze and empty. cold water will dispense.
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | GE Refrigerators
I have a GE Profile Stainless Steel refrigerator; the Model number is PFS22SISBSS. The ice maker stopped working.
Jul 01, 2008 | GE Refrigerators
Icemaker just stopped making ice
As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
May 15, 2008 | GE PSS26MGS Side by Side Refrigerator
Dec 28, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
12 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
