Question about Whirlpool RF262LXS Kitchen Range
I have whirlpool model #RS696PXGB13 and broke the glass top. I have a replcement coming. Can I change this myself?...if so how?
  • vcastillo209 Jun 23, 2009
    The # you listed is not the same model # I have.
    the solution was not clear to me...thanks...for nothing.
  • 952 Answers
1. Lift the cooktop by both front corners until the supports lock into
place.
2. Lift the cooktop from both sides while pressing the support
rods back to unlock them.
3. Loosen the support screw from the bottom part of the cooktop
4. Take out the electric terminal from the old Ceramic Glass
5. Replace the Ceramic Glass then plug everything back in
Posted on Jun 22, 2009
How to put plexi-glass in convertable top
That requires allot of skill and special equipment.
Jun 15, 2012 | 2001 Saab 9-3
I have a maytag gemini double oven stove and I broke the glass cook top, can I order another glass top and replace it myself?
yes you can order it,it's around 200 dollars,and it's a little work to do this,when you call your parts store give them the full model number off of the machine,the part number i found is 5706X371-09 and it's around 200 dollars but 10 models came up and this seems to match all of them but you might have a different color so check when you buy it.
Apr 18, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Can i replace just the glass on my stove cooktop
yes u can,, usually glass tops are fairly expensive though 200-900 dollars just for the glass plus service and labor to install it unless u feel comfortable pullin it out and removing all screws around base and removing glass and transfering all the elements over and switches as most have the elements mounted to glass underneath. u can get a price and part number for the glass top by going to sears.com and go to parts and service and look up parts by model number to get info.. model number will be underneath on sticker.. hope this helps.. you can do this yes but like it said usually its fairly expensive...most had a 5yr parts warranty if that applies to you just dont tell them u broke it say it occured natuarally as they wont cover it if u damaged it urself by droppin sometin onn it.
Feb 06, 2010 | Whirlpool Kitchen Ranges
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
The glass top broke- is this replaceable?
Yes, but it costs $350+ just for the part you need. Might as well scrap it and buy a newer convection model.
Aug 12, 2009 | Whirlpool Accubake RF362LXTS Electric...
GE Spectra model JBP78COB1CC
ok Jim - to answer your first question, you can still use the oven but it will be less efficient and will probably not operate at the temperature you set it at.
Yes you can replace the glass yourself. ?You will need the right glass for your model of stove and the installation kit to go with it.
You can purchase these at a website such as www.repairclinic.com
Feb 02, 2009 | GE Spectra JBP78 Electric Kitchen Range
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Cracked cooktop on Kitchenaid built in cooktop
oh im sorry about that.yes you can purchase a new one.i would shop one line because more competition and then would get a better price you will need model and ser# .just check them out before giving your money.ive sold some last year thru sears as a tech and they were about 400$.you can find a glass top range on sale for about that much,but wont be an kitchen Aid
Jan 24, 2009 | Whirlpool ED2FHEXN Side by Side...
Cooktop glass broken - need a replacement - where can I find it?
It all depends on our capabilities... The top isn't all that difficult to replace. If it were me, I would call GE Factory Service 1-800-432-2737 or schedule an appointment online at www.geappliances.com as there may still be a warranty on the top which is expensive...
Dec 23, 2008 | GE Profile JP930 Electric Cooktop
Whirlpool RF262LXS Kitchen Range Logo
139 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
