Question about Pioneer VSX-D510 Receiver
When does the cooling fan start in Pioneer VSX-D814?
4 Suggested Answers
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: I have a pioneer dvd
LAZA got a haircut .
Posted on Dec 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hello, help me please, my
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 15, 2011
Why does my Pioneer Elite VSX 50 overheat?
Shorted component/s at its audio output stage circuit. Check and replace it. Check the site linked here. Pull up older posts. Check whether its cooling fan works properly.
If you want further advice over phone; visit https://www.6ya.com/
Aug 23, 2016 | Pioneer Elite VSX-50 7.1-Channel 3-D Ready...
My pioneer vsx-518 has a noisey cooling fan, is that normal?
Before replacing the fan, check for loose mounting hardware and cracked or damaged blades
Feb 09, 2013 | Pioneer VSX-518-K Receiver
I have the pioneer vsx-d814 with the xxd3069 remote but the remote wont work anything and it has power.Need help
Hello
Get into this link and see the faults that can occur with a remote control. Just check all that suggested. Even after all che checks are found OK ,and your device does not repeond to the remote control, the remote sensor inside the unit must be checked.
http://www.fixya.com/support/r8733688-common_faults_in_infrared_type_remote
Dec 15, 2011 | Pioneer XXD3033 Remote Control
Hello, help me please, my receiver is pioneer vsx-d814, when I set on AUX, DVD/VCR, TV, CD and turn volume more then 40 it says "overload" and power off, but when I set DVD/LD it's Ok.
May 15, 2011 | Pioneer VSXD814 Receiver
Pioneer receiver vsx d814 amp error
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Mar 21, 2008 | Audio Players & Recorders
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Dec 10, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-D510 Receiver Logo
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
