Question about Kodak 6800 Thermal Photo Printer
One pixel wide line across whole picture
We are on a generator that had some problems recently (for about 3 monthes) when we had severe power interuptions the printers one at a time started to have the same problem. I have canabalized the head on another printer with a different problem and the image prints flawlessly.I need to replace the head on the 3 remaining printers........How can I buy a Print head?Oh by the way I am in Belize Central America..........THANKS
Bret
Deberias de revisar las conexiones electricas y ver el punto a tierra, luego hacerle una limpieza periodica para que acumule suciedad y con respecto a los cabezales la verdad ni idea de donde los puedes conseguir pero si consiges me avisas
Posted on Jul 23, 2010
  • 256 Answers
You didn't tell us the printers manes and models, so I could not check. I bought my printhead from: http://officestoredepot.com/. Search for printheads and compare prices to get the best deal.
Posted on Jun 22, 2009
Jvc rear projection tv
Do yourself a favor and dump this old TV, new ones are much better and cost is very low due to low demand.
May 18, 2012 | Televison & Video
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Hi, I have a 6 month old laptop Acer emachines E625 and turned it on this morning to find 3 thin black horizontal lines have appeared (with about 2 or 3 smaller lines above each of the 3 lines) at the...
Attach an external monitor to your PC. If the problem continues there, it's your graphics card.
If the problem disappears, you have stuck/dead pixels.
You could try a very gentle rubbing of the pixel(s).
Feb 03, 2010 | Computers & Internet
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dell Axim problem
Most likely a bad connection along the sides of the screen causing a line of "dead" pixels. I have a similar problem with an old GPS reciever (several lines). You could attempt to repair but that would be risky unless you purchased a new working screen and replaed the entire screen (can find on ebay at times)
Apr 28, 2008 | Dell Axim X5 Pocket PC
Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
Nov 21, 2007 | Sony KDF-E55A20 55 in. LCD Television
Vertical lines on LCD monitor
You have capacitor problem in power supply, if many lines then replace the bigest cap and find anymore that needs replacing. Its an AC filter problem.
Sep 14, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Two light lines have just appeared
Your driver transistors are failing on those "Rows" of Pixels.. a common problem .. you could try "Pixel Reviver" software from here http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor see if that helps.. but it possibly is on the way out sorry..
May 22, 2007 | Sony SDM-HS75/B 17" LCD Monitor
Kodak 6800 Thermal Photo Printer Logo
139 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
