Question about Vans Winter Sports
Fiat ducato 2.8 jtd van speedo went backwards speedo and petrol gauge and heating gauge not working after taking battery off to charge after going flat van started 1st time but fault came up ?
5 Suggested Answers
  • 978 Answers
SOURCE: fiat ducato van 2litre jtd turns over but wont
strange that it should start with a jump ,i would be looking at the battery to make sure not a dead cell in it
Posted on Oct 18, 2011
  • 978 Answers
SOURCE: my petrol gauge gives the wrong reading going from
could be a bad connection on sender unit in other words a loose wire check connections at fuel tank
Posted on Oct 19, 2011
matt_sams
  • 124 Answers
SOURCE: no power to fuses on Fiat 14 ducato van (1987) alternator charging, headlights, horn, hazard all ok, no power to indicators, wipers, heater fan, fuel gauge, temp gauge. all fuses are ok, engine starts
Sounds like the relay is bad, look in the fuse panel or under the dash for a lil black box, they are usually appx 1"' x 1" and there should be several of them. You may want to check owners manual or a repair manual to find the location. They should be listed in the schematic of the fuse box as well.
Posted on Jun 07, 2012
  • 3202 Answers
SOURCE: How to check valve timing and injector timing on Fiat Ducato 2005 2.8 JTD engine?
If I knew the answer the description would be too protracted for the space and time available here.
You are likely to be able to find a how-to video on youtube. If the injection system is a common rail type the timing will be electronically controlled.
Engine manufacturers are increasingly not using timing marks as the engines are built by robots and timed by jigs, and an increasing number of setting tools are needed to work on engines in the aftermarket.
Posted on Aug 08, 2016
Hi I have a fiat ducato 2.8 jtd and conrod has spun a bearing and cannot read size on it as its disintegrated how do I find number four it number 4
take another cap off and read the size
what you are doing is a short cut to costly repairs as a spun bearing usually requires a new con rod as well as bearings
Aug 25, 2017 | Fiat Cars & Trucks
Thanks for the answer Vernon if the gauge is fluctuating can I still go long distances driving or will the engine overheat on the Fiat ducato
While I don't personally know the Fiat Ducato all that well. Typically when this happens with a car (any car), it is not a good idea to drive long distances with it. You should have the car repaired before it really over heats and suffer catastrophic failure
Mar 18, 2017 | Fiat Cars & Trucks
Fiat ducato 2.3 jtd none starter!
have you had the injector spray pattern checked ? i would advise getting that done and then work backwards from a known good component, also have you had the OBD codes read as these should help pinpoint the sensor/switch etc at fault , actually do thes ethe other way round OBD first , keep me posted if you wish
May 13, 2015 | Fiat Cars & Trucks
What type of gearbox oil to be used as well as engeen
lost the operators guide, there in glove box?
what enigne
what transssion
over heating has over 10 reasons.
even the gauge fibbing, I never trust it, i use my tools that I trust, or go mad. (i use a IR pyro gun) sold for like $15 bucks. here.
look ma. no burned hands....
to do DIY , you need to know first engine type and size and transmission type.
do not guess.
find them.
i have no idea what country you are in, and cant help much
I think ALfA Exports all over world, but not USA>
(came back in 2006 by FIAT)
In 2012, this re-entry was again delayed, this time to early 2014(wiki)
so where is it.?
if you wiki your car, all that is clear all that complexity.
of options,.......
1910 to now
the 156 wiki shows all these eng/trans options
perplexing huh , well the VIN or chassis tag shows what you have.
1.6 L I4 16V (TS) petrol
1.8 L I4 16V (TS) petrol
2.0 L I4 16V (TS) petrol
2.0 L I4 16V (JTS) petrol
2.5 L V6 24V petrol
3.2 L V6 24V petrol
1.9 L I4 t/c diesel (JTD)
2.4 L I5 t/c diesel (JTD) Transmission 5-speed manual
6-speed manual
5-speed semi-auto (Selespeed)
6-speed semi-auto (Selespeed)
4-speed automatic (Q-System)[3] end wiki quote.
the engine oil may need special selections, for DOHC engines and turbos and for sure Diesel
and for sure which tranny
why not buy the operators guide for your car from FIAT?
or used off of fleabay
or week long searches on google.
Jul 03, 2014 | 2000 Alfa Romeo 156
No power to fuses on Fiat 14 ducato van (1987) alternator charging, headlights, horn, hazard all ok, no power to indicators, wipers, heater fan, fuel gauge, temp gauge. all fuses are ok, engine starts
Jun 07, 2012 | Fiat Regata Cars & Trucks
Fiat ducato van 2litre jtd turns over but wont start,but will start straight away with ajump
Oct 15, 2011 | Cars & Trucks
My petrol gauge gives the wrong reading going from full to empty on my fiat ducato van. how can i fix it.
Sounds like the sending unit is going out. The sending unit has a float that measures the fuel level. They can start sticking in different levels. It is more than likely located inside the fuel tank.
Sep 24, 2009 | 2006 Fiat 124
Find petrol and temperature gauge vw1991 Autotrooper 2lt petrol
dealer only for the parts ,and they are all available
Mar 30, 2009 | 1986 Volkswagen Wagon Camper
Winter Sports Logo
87 people viewed this question
Top Vans Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Vans Winter Sport Expert? Answer questions, earn points and help others
