Question about Timex Ironman Triathlon Heart Rate Monitor
How to use reebok hrm - Timex Ironman Triathlon Heart Rate Monitor
I bought a Forerunner 50 with HRM and Footpod. Initially the footpod wouldn't work, but HRM would. So changed the battery and footpod is fine. However, HRM now won't work. Just replaced the battery in that...
I had a similar problem. First my hrm worked and the footpod did not. Then I tried to pair manually (for the umpeenth time) when the hrm was too far away, and I lost that pairing, and it still didn't find my footpod. Then I wet the hrm sensors and tried pairing again and then it picked it up. Finally, I switched batteries in the hrm and footpod and then it picked up the footpod. Now I'm headed to the store to stock up on batteries. Kinda upsetting that I have to buy batteries when I just got the thing, but probably costs less than the postage for sending it back!
Feb 21, 2009 | Garmin Forerunner 50
Heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
Feb 20, 2009 | Garmin Forerunner 50
Garmin 405 pair to wrong HRM
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Jan 04, 2009 | GPS
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
Heart rate monitor question
Price is always a consideration when it comes to HRM's. You can easily go to Target and purchase a $40 HRM, but consider the quality. Buying a HRM is an investment and you get what you pay for. You don't have to spend hundreds of dollars to get a high quality HRM, but you do want to make sure that it will last a long time. When buying a HRM go for trusted brands such as Polar, LifeSource, or Mio. Some of the cheaper models won't fit as snugly and may be heavier than higher quality brands.
Aug 27, 2008 | Haba Drive Fingertip Pulse Oximeter
Garmin Forerunner 305
Make sure the small prong under the battery is bent out a bit, sounds like an intermittened connection problem.
Mar 17, 2008 | Garmin Forerunner 305 GPS Receiver
Exercise & Fitness Logo
Top Timex Exercise & Fitness Experts
Dennis Fitzsimmons
Level 1 Expert
Jimmy Accardi
Are you a Timex Exercise and Fitnes Expert? Answer questions, earn points and help others
