Question about Reebok Exercise & Fitness
How reebok hrm chest strap be paired with iphone
3 Suggested Answers
r321567499
  • 74 Answers
SOURCE: Accessing the battery compartment of Reebok HRM
I think this link will be helpful.
http://www.iconservice.com/reebok/manuals.html
Posted on Jan 07, 2009
SOURCE: Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Posted on Jan 19, 2009
Garmin Edge 705 Heart Rate Monitor Not Working
It could be that there is a failure in the circuit between the two pads on the chest strap and the HRM electronics in the middle. If it won't work at all try putting the battery in backwards for a few seconds (this is supposed to accomplish a reset) and then try re-pairing it with the Garmin. If this doesn't work, I suggest a new HRM. I've hadevery good luck with my Wahoo TICKR and a Garmin 502.
Mar 24, 2017 | Garmin Cycling
I just received a brand new Garmin FR 60 with HRM monitor strap and ANT USB from Amazon. I followed the directions to use the strap[wet the electrodes, strap it over my chest, with the Garmin logo facing...
navigate using mode button to enter into watch's menu tree for settings/ sport/ run/ heart rate and turn on the heart rate monitor to hopefully detect and scan for the garmin ant+ protocol heart rate strap!
Sep 22, 2011 | Watches
Garmin Edge 305 HRM problem
Try to pair his unit with your strap and it won't work, you have a bad strapl
Feb 16, 2009 | Garmin Edge 305 GPS Receiver
Watch won't read heart rate
It could be the battery on the strap is not good. However just to be sure make sure you are wetting the strap and it is around chest, front should sit right about on the bottom of pectoral or chest, if you are female make sure it is under your sports bra the bra band will be over it. I would start warming up then hit the start button it should work.
Feb 06, 2009 | Polar M61 Heart Rate Monitor Watch HRM M61
Garmin 405 pair to wrong HRM
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Jan 04, 2009 | GPS
Timex M515 Heartb Rate Monitor in correct readings
I´m experienced the same problem of incorrect readings after a long time without use. I cleaned the rubber parts of the chest strap with soap and water, than I use some silicone grease or other silicon liquid to keep the rubber hydrated. Make a careful cleaning in the contact area between the rubber and the plastic parts, the fissure in these area use to be full of "sweat dust".
Jan 03, 2009 | Timex Digital 30 Lap Heart Rate Monitor...
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Exercise & Fitness Logo
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
