Question about Verbatim 97993 Wireless Multi-Trac Blue Led Optical Mouse Blue
How to adjust speed?
Win7 does not recognize it as a MS mouse, so no adjustment options.
My ViewSonic VA9036 keeps saying I need to adjust the resolution but I don't know how to please help me
You can change the resolution by right clicking the mouse while on the MS screen and you will get a popup window with a few options and 1 of them will be resolution. It is point and click after opening that page
Mar 17, 2014 | Computers & Internet
Keyboard Not Recognized
You may need to enable the keyboard in the Bios as a USB keyboard.
Mar 14, 2014 | Viotek Vio Hawkpeck Wireless 2.4GHz...
Dc5700 won't connect usb mouse and keyboard after disconnect
why run dead XP?, is the PC ONLINE? or off/?
The USB plug and play is failing,
you do know MS killed dead Plug and Play for XP 4 years ago right?
the top failure of any pc running XP would be USB devices.
USB devices are extensive in scope, endless types
and top of the list are mice, and keyboards.(vast types exist))
The PnP engine scans the local driver cache first.
if no mouse (example 1) is found to match your unstated mouse
then it must do what? go on line, to MS.com
and MS pulled the plug..... just like they did
on
w95
w98
ME
W2000 and vista. and XP 4+ years ago !
time to upgrade, for sure.
a counter argument would be that the virus magnet XP is infected.
as ALL ARE NOW and worse every day forward!! for eternity
Feb 07, 2018 | HP Compaq dc5700 Microtower - Free Flat...
How to slow the scrol of the mouse on microsofet wirelless 3000?
Assuming you are on Windows, go into your control Panel and go to your Mouse Settings. You show be able to slow it down from there. Scroll Speed will be where you want to adjust.
Start>
Control Panel>
Mouse>
Pointer Options Tab>
Select a Pointer Speed>
NOW ADJUST YOUR SPEED AND THEN CLICK OK
NOW Exit this small window if it doesn't do it automatically and VOILA you are done!
Mar 10, 2011 | Microsoft Wireless Desktop 3000 Keyboard
How do I change the speed of my mouse pointer?
Windows 7
  1. Click the Start button , and then click Control Panel.
  2. Click Hardware and Sound, and then under Devices and Printers, click Mouse.
  3. In the Mouse Properties box, click on the "Pointers" and "Pointer Options" tab, and adjust options.
  4. In the "Pointers" tab, you can change the shape and size of your cursor by changing the "scheme."
  5. In the "Pointer Options" tab, you can change the speed, visibility, and other characteristics of your pointer.
Mar 10, 2011 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
The card was working fine in windows xp. But i recently installed windows 7 and the card is not detected.
need a new driver for Win7 for the SB card....for Win7 HW mafgs have not develoepd any drivers as the Win7 source code was not provided to the Hw nfgs by MS....
MS has develoepd std drivers for all HWs that can install any HWs....
you need to register with MS your copy of Win7 and download all updates and the SB card will auto install once all updates are done....
Feb 07, 2011 | Creative Labs Sound Blaster Live! 5.1...
The mouse is jumpy and the it deosnt move smoothly
click start control panel,mouse you can speed up the mouse
also under pointer options you can speed up the mouse you must click apply after you have made any adjustments
hope this helps
Dec 21, 2010 | Computers & Internet
When i move my cursor down the page moves slowly and lineing comes. pls help
Go to Start
  • Then go to control panel.
  • Go to control panel (If you are using Windows XP go to settings and then select Control Panel).
  • In the control Panel there will be mouse icon (For mouse settings).
  • Click it.
  • Then select, in the Window that opens, pointer options
  • On the top you can adjust the speed of the mouse pointer.
Feel free to play with the settings to get desired results.
If the speed of the mouse pointer is not adjusted with above directions consider using a good Anti Virus to scan and clean your computer.
Nov 30, 2010 | Computers & Internet
Verbatim 97993 Wireless Multi-Trac Blue Led Optical Mouse Blue Logo
35 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
