Question about Standard Horizon CP170C GPS Receiver
Gps will not aquire satellites - Standard Horizon CP170C GPS Receiver
Garmin 76cs will not aquire satellites after powering up
plug it into a computer and update the firmware. my TomTom has done that a couple of times.
Aug 29, 2012 | Garmin GPSMAP 76CS GPS Receiver
Will not aquire satellites
This is a common problem on the Nuvi 3xx and 6xx series and is caused by a failed component. Please see this link for troubleshooting information.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Nov 23, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin 200w has trouble aquireing satellites?
Go to the Garmin dot com website and follow prompts to download the software and the firmware and software updates - they are free.
Jun 12, 2010 | Garmin nuvi 200W GPS Receiver
Easy problem to fix. Please see this link for more info:
- Jim
Nov 28, 2009 | Garmin nuvi 350 GPS Receiver
N ot able to aquire a satellite signal for two
have you downloaded the "HotFix" software update for the problem from Garmin yet? if not u will need a mini USB cable (avil on ebay for $5) and then register the GPS at this site www.mygarmin.com and select support or downloads and follow instructions..
Oct 01, 2009 | Garmin nuvi 255W GPS Receiver
When i put my Navman icn 320 on sometimes it takes upto 30 to 40 minutes waiting for the GPS signal to come through
Hello adamant,
In order to determine your current location the GPS needs to receive telemetry information from several GPS satellites. In order to do that it needs a clear view of the sky. This should happen fairly quickly, typically within a few minutes, but depending on how and where you are operating the GPS the process could take significantly longer or the GPS might be unable to aquire a satellite lock at all.
Local geography such as mountains, hills, tall buildings and heavy forest can block the GPS's ability to receive satellite telemetry. The same thing can happen if you are trying to operate the unit indoors or inside of a vehicle without an external antenna. That's why most GPS receivers are installed on the dash board of the car: the windshield and side windows provide it the best view of the sky.
It is also possible that there is a problem with the GPS receiver or the antenna. To test it, try using the device outside in a relatively open area with a clear view of the sky in all directions. It should aquire a satellite fix in about five minutes or less.
Best Regards,
Ken
"Go Ahead. Use Us.
Jul 08, 2008 | GPS
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Standard Horizon CP170C GPS Receiver Logo
61 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
Mike Mullett
Mike Mullett
Level 1 Expert
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
