Question about Sharp AR-5316 Advanced Digital Imager Copier
TONER INDICATOR BLINKING - AR 5516 - Sharp AR-5316 Advanced Digital Imager Copier
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Posted on Nov 10, 2008
xptareq2000
  • 1447 Answers
SOURCE: My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
Posted on Jan 27, 2010
  • 4 Answers
SOURCE: Problem for Sharp AR-5320 Black
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Posted on Aug 22, 2010
  • 5 Answers
SOURCE: I have got my Sharp AR 5516 but my computer is
Go to sharp site and download patch for windows 7
Posted on Jan 16, 2011
muhaemin89
SOURCE: H2 problem sharp AR 5516
is that mean, I have going down to simulation by pressing # interrupt 0 interrupt then machine wil shutdown mode than press 14 then press start.
is that true? because I mess up with my copier cannot print because code H2.
Posted on Sep 30, 2012
Can toner for sharp AR-5620235ft work in a sharp AR-5516 021ft please help? give me some ideas people ?
Yes. It is compatible. But, before switch it ON; after the replacement, keep a distance from that device. It will be safe for U.
Sep 07, 2016 | Sharp Office Equipment & Supplies
Sharp Ar-5516 toner light problem continue blinking
If the toner light has a line under it your waste toner container is full and needs to be emptied.
May 04, 2016 | Sharp Office Equipment & Supplies
AR-5516 is bleaking a man near toner signal point. why is this bleking
its blinking because you need a technician to do the preventive maintenance of your copier...
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
May 22, 2011 | Sharp AR-5320 Black and White Copier
Jan 27, 2010 | Sharp AR-5320 Black and White Copier
Sharp digital 5516 drum life indicator along with a man flashing. Also any compatible toner available for sharp 5516.
Try a reset first (Press #, interupt,c,interupt, then 14 start), If it pesist, Check the drum for injury lines, the developer for inpurity and clean the toner catradge proper, the close all machine doors. Good luck.
Apr 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
