Question about Sector Watches
Sector 2653976025 reset after battery exchangeor
Sector sec 200 battery change
you should first take watch to jeweler to change battery but if you do it yourself, make sure the battery is in correctly and if it has a metal bar across it make sure that is in properly as well
Jan 28, 2012 | Sector 200 3253980105 Watch for Men
Reset
Some watches will change the day/date starting at 1130pm and not be done changing both until 230am. So yours may be normal for that particular watch. BTW, that is when the date does change to the next day, at 1201am. Hope this helps.
Jun 16, 2010 | Sector 550 Series Chronograph R3253993035...
Resetting a sector adv 2500 after battery change
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SECTOR watch manuals. Rate me, please .
Apr 08, 2010 | Sector 250 3253251115 Watch for Men
It stop working, analog and digital
Unfortunately the watch may have been on display for some time and the battery may have run low. If you go back to the place of purchase they should change the battery free of charge. Make sure that you have the watch resealed to manufacturers water resistance rating or you void Sectors warranty. The retailer may also replace the watch with a model in stock but you may have the same issue with display time effecting the battery life.
Sep 17, 2009 | Sector 3251908015 Mountain Master watch
I need a sector watch expert.
There are no bad motions for watches - they are designed to withstand all motions, except very hard knok/hit.
You do not need a Sector watch expert, as all watch brands use movements made by few manufacturers and all decent watchmakers know them from A to Z. Only very expensive watch manufacturers produce their own in-house movements - Sector is not in that league.
Contact that shop and ask for full explanation what and why went wrong.
Rate me, please.
Aug 11, 2009 | Watches
How to change the battery on a Sector 600 series watch
Open the caseback. Undo the battery contact. Get the battery out. Memorize all the writings on battery and buy exactly the same one (do not mind the manufacturer).
Install the battery. Put the caseback on.
Rate me, please.
Mar 26, 2009 | Sector 600 2653917025 Watch
Sector 255 need to contact sector
need help in setting time on sector 550 2653955025.
Nov 16, 2007 | Sector 2653940025 Wrist Watch
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Watches Logo
32 people viewed this question
Top Sector Watches Experts
aravind shet
aravind shet
Tom Chichester
Are you a Sector Watch Expert? Answer questions, earn points and help others
