Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
What the good degree for humidity - Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Can my 3 in 1 air cooler also be used as a dehumidifier
an air cooler is a dehumidifier by definition
It cools the air around the evaporator giving you cool air and at the same time any humidity in the air is condensed into water and drained off
to understand air conditioner principles it goes something like this
we sweat and the more we sweat is because of the humidity in the air
if the air temp is 30 degrees c with a humidity of 75% then we feel that it is a very hot muggy day simply because the humidity stops the sweat from evaporating and allowing the skin to cool
Now it you take the humidity out of the air and at the same day temperature , you will actually feel cool because the sweat can evaporate and cool the skin
now you can understand that the best setting for air conditioning is 25 degrees c because if the setting is lower then the skin gets too cool because there is no humidity to restrict the evaporation of the sweat
modern spilt systems have a mode called comfort where the fan and the compressor work to maintain a constant level of humidity when sleeping and you don't get cold especially towards the morning
Jul 29, 2015 | Dehumidifiers
Dehumidifier does not reduce humidity.
Good Afternoon Miguel,
I understand that your Frigidaire dehumidifier, model# LAD704TDL, is not reducing the humidity, due to the coils constantly freezing up. I also see that it is located in good temperatures and in a good position. I suggest contacting the manufacturer directly. They should be able to point you in the right direction to having your appliance fixed. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Dehumidifier LAD704TDL
Unit was charged w/ 10.6 OZ of R22 and don't seem to be working very good?
About 61 PSIG or 33 Degrees F. If you look at the gauge on your refrigeration manifold it will give you the numbers. What is Max, it changes with temperature and humidity and without very involved controls the absolute max will not be realized over the normal ambient operating range. Good Luck
Apr 20, 2014 | Fedders A7DH45B2A Dehumidifier
BUCKET DOES NOT FILL WITH WATER
It could be the coil & condensor are dirty.
Or it could be that the humidity level is below what the unit will work at. Below 50% humidity and or 70 degrees Fahrenheit, it generally will not do much.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Aug 08, 2013 | Whirlpool 75-Pint Dehumidifier
I am showing a HI on my current humidity/set humidity display what does it mean
The HI indicates that the current humidity is 90%+ in the room/unit. You should check if the filter is clogged. I've seen this message in dryer locations when the dehumidifier coils ice up. Check the coils (behind the filter) for any build up.
If this is a brand new dehumidifier, leave it on for an hour to see if it auto-defrosts. (A similar wait is needed if the room is cooler that 60 degrees F.)
If the unit continues to freeze up and the room is over 60 degrees, you may have a refrigerant leak in the dehumidifier. If it is still under warranty (5 years on the cooling system), contact Haier. The warranty service number is 1-877-337-3639.
The manual for the DE65EK is available here: www.haieramerica.com/downloads/dl/file/id/26/de65ek_manual.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Dec 24, 2012 | Haier DE65EK High-Efficiency ENERGY STAR...
I've misplaced the owner's manual on a DEN 500 P. What is a good basement setting for Summer in Central Ohio? Is a manual available on line?
I bought a cheap digital humidistat at Walmart to keep an eye on the humidity in my basement. I hung it on the wall not too near my dehumidifier. I have found that the settings on the dehumidifier are misleading, but I found a setting that keeps my humidity between 40% and 55% (at around 70 degrees), as measured by the humidistat.
Jun 04, 2012 | DeLonghi DE500P Dehumidifier
Control panel explanation
80% means the humidity will be at 80%
You probably want a setting of 50 or 60% if you are trying to keep a damp area dry.
When it is 20 degrees outside, it will probably by below 50% humidity inside so you need more humidity, not running a DEhumidifier.
CONT is for continous running - you probably don't need that setting
Jan 03, 2010 | Dehumidifiers
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
Temp and humidity levels are not correct
It sounds as if the temperature sensor probe is touching the cold coil inside. The sensor is located in the incoming airflow, in front of the cold coil. It must not touch the coil. This should be visible with the cover off. You can gently bent the sensor away fron the coil, 1/4-1/2" of clearance is plenty.
Jun 06, 2007 | Maytag M7DH45B2A Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
41 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
