Question about Frigidaire GLRS237ZA Side by Side Refrigerator
Frigidaire GLRS237ZA Side by Side Refrigerator - Water is leaking from the filter. A small stream of water comes out of the dispenser, but most leaks into the fridge. Will replacing the filter fix the problem? It is time to change it.
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
fridgetech
  • 473 Answers
SOURCE: when icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Posted on Nov 03, 2007
SOURCE: Frigidaire Water Leak
We had the same problem with water spontaneously pouring out from behind the ice maker dispenser like Niagra falls. Turns out that the water inlet valve was stuck in the open position. This must be a fairly common problem with this model because it took almost two weeks to get the part since it was sold out.
(Part # 241734301)
We were concerned about this happening again, but it appears Frigidaire has upgraded the part (it is not exactly the same as the old one), but you may want to consider getting a "flood safe" water line from Home Depot just to be sure. We were lucky that we were home when the water started gushing. Otherwise, it would have flooded the whole house.
Posted on Aug 13, 2008
SOURCE: water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Posted on Aug 24, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
Why does my frigidaire washer leak
Hello friend, I appreciate your post!
I see you are asking about a Frigidaire washer leaking but your question is labeled under refrigerators. If your washer is leaking it could be a problem within your motor, water valve, drain pump, or seal inside your washer. If you are speaking about a refrigerator it could be an issue within your water valve, water filter, or an air leak causing condensation.
I would recommend having a professional come out to the home for a proper diagnose and repair. I hope this is helpful. -Matt
Aug 17, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
Leaking water
IF YOU CHANGED THE FILTER AND GOT WATER OUT THE DISPENSOR AND HAD A RUSH OF AIR COME OUT OF THE LINE. YOU MAY HAVE GOT WATER UNDER THE DRIP TRAY. WATER WILL THEN COME AROUND AND APPEAR THAT THE DISPENSOR IS LEAKING. OR YOU MAY HAVE NOT PURGED ALL OF THE AIR. LET ME KNOW.
Apr 25, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
Water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water leaks out of the bottom of the refrigerator when I use the water dispenser. I can see the water dripping out of the tube where the water lines go to the filter from the bottom of the refrigerator.
that means you have a leak or you need to change your filter. when that happen means that is a blockage or restrition on the course of the liquid(water) most cases is the filter on it`s maxim capacity of filtration and the water comes out to the easiest opening.
Mar 08, 2009 | Frigidaire FRS26R4A Side by Side...
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water dispenser
limed up at end of spout/ clean lime out with small screw driver or somthing small to get in end of spout/ once lime is clean water will come out normal
Aug 05, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Have you found a solution to your problem? We started having a a similar problem with our Frigidaire. Thank you.
Jun 18, 2007 | Frigidaire PHSC39EESS Stainless Steel Side...
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
