Question about Coffee Makers & Espresso Machines
Tecnico 105 Brasilia coffee machine those not taking in water and blow off the fuse on the board
2 Suggested Answers
SOURCE: Everything sounds like its working...but nothing.
Another thing might be your coffee is too finely ground or tamped too tightly.  If water comes through the filter basket, try using a little less coffee and tamping less firmly.  If that works, you're all set.  If you still have a problem, you may need to switch to slightly coarser grind.
Posted on Oct 16, 2007
Will not heat water
When my machine quit heating water, the first thing I did was check to see if power was getting to the element. In my case there was, so I changed the element and it worked. I would check that, and if there is no power trace the wires to the next component.
Apr 08, 2014 | Brasilia Portofino-Exec-3R Portofino Exec...
Very hot weak bitter coffee
Ascaso dream temperaturegauge
It should be between 80°C/180°F degrees for the coffee and 100°C 212°F degrees for the steam.
You may have to replace the thermostats.Use thermal paste for correct fit.
Ascaso boiler thermostats 2
Feb 05, 2014 | Ascaso Dream Espresso Machine
My delonghi caffee nero machine-the coffee maker wont work,the hot plate doesnt warm either(although the lights come on. the espresso maker part works fine. Someone mentioned there is a fuse which blows...
If expresso maker part works, the fuse is ok. I think that the resistence of the hot plate is interrupted. You must use the guarantee's facilities. I think it is two years available.
Mar 07, 2011 | DeLonghi Caffe Nero BCO264 Espresso &...
My keurig only dispenses half of a cup of coffee. Half the water comes through the kcup and the other half is despensed back into the water reservoir
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Nov 03, 2010 | Keurig B60 Coffee Maker
When machine is turned on the electrical parts blow a fuse. it is not a fuse or voltage problem but water seems to be falling onto electrical parts
if water gets into the electrical parts it will cause it to short out to ground, tripping your breaker/fuse. seal her up and see what happens.
Jan 11, 2010 | FrancisFrancis! X1 - Stainless Steel...
The pressure left the group!
Check the top of the group, you will find a nut which is about 19mm, within that nut is a micro-screen, and a small jet. Make sure the machine is cool and the inline water is turned off. The jet maybe clogged, get a paperclip or some pipe cleaners and clear, check screen for buildup, there might also be a small amount of sand in there(Minerals from the water), easiest way to clear it slowly open the inline water. BEFORE REMOVING THE NUT CHECK TO SEE IF THE GASKET UNDER IT IS TEFLON OR SILICONE. IF TEFLON GO AHEAD, IF NOT MAKE SURE YOU HAVE ANOTHER ONE ON HAND BEFORE YOU PROCEED.
Apr 06, 2009 | Coffee Makers & Espresso Machines
Bunn blows fuses
This is usually caused by the tray where you pour in the water leaking where it mounts down to the tank. it's probably cracked just enough to allow water to seep out, crossing wires on top of the tank, causing a dead short. There is also a seal that goes between the pour-in tray and the tank that sometimes starts to leak. This tray can be replaced if you can find a used machine that doesn't have the same problem. Before you buy one, though, you should take the top of your brewer off, remove the pour-in tray (careful - they get brittle over time) and look on the top of the tank for signs of water seepage. If there are no signs, then your heating element is most likely blown.
Oct 14, 2008 | Bunn BT10B Coffee Maker
It sounds like your filter is clogged.  This can be tricky to unclog, but use the pin that came with the machine.  I have had the most success when I use the pin and try to run H20 (no coffee) through the filter basket.  Sometimes takes several tries, but eventually blows out the clog.
Sep 14, 2007 | Breville Die Cast 800ESXL Espresso Machine
Coffee Makers & Espresso Machines Logo
16 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
