Question about Whirlpool LER4634J Electric Dryer
Electric whirlpool dryer turns & heats but does not dry
My electric, front loading whirlpool dryer heats up and it seems the tub is turning but even after running for 2 hours, the light weight cotton clothes are not dry. the dryer also shows no collection of lint in the dryer's lint basket -- even after having towels in the dryer.
The flames on the dryer come on for a couple of minutes and then shut off then comes back on about 5 min. later,. the cloths don't get dry . this goes on the whole time the dryers running, take 2hours to dry a load of cloths
Posted on Jun 24, 2009
  • 79 Answers
Check the exaust pipe, I believe you will find it plugged up. You may also try disconnecting the vent line from the dryer and then running the dryer, put your hand over the exaust port, you should feel all kinds of air flowing from the port, if not you have problems with your blower.
Posted on Jun 23, 2009
  • 5,911 Answers
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the section that discusses proper dryer ventilation. The fact that you don't see any lint collection in the lint trap could be a symptom of a dryer that is clogged, or an exhaust vent clog. An easy way of determing whether or not the problem is with the dryer, or the ventilation, is to remove the exhaust vent line from the back of the dryer and attempt to dry a load as normal. The air flow coming from the back of the dryer should be forceful and warm (about 140 degrees). If this is the case, the problem is NOT the dryer and may be attributed to something in the ventilation ducting from where it leaves your dryer to where it exits your home. An inspection of the vent ducting should be done to confirm it is clear and free of clogs or kinks.
If the air flow is weak, then you have a clog INSIDE your dryer. An inspection of the dryer blower fan housing should be done to ensure the fan is turning unobstructed and there are no clogs. If the air is cool, you probably have a failed component in the heating circuits.
Read through the link I provided and let me know if you have any questions. I hope this helps you.
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Dryer takes 2-3 hours ro dry a load of wash
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 05, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 02, 2010 | Whirlpool Dryers
My 4 1/2 year old electric Whirlpool dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 26, 2010 | Whirlpool WED5100SQ Front-Load Electric...
My 29" Whirlpool dryer runs but no heat.
This could be a thermostat, the heating element, or even a wire burned off (or loose).
Mar 31, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Whirlpool Duet Front load dryer
Normally this condition is caused by a broken belt...or a burned up motor
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer no heat but runs
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Whirlpool Duet GEW9250
more than likely a short in the user interface
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
196 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
