Question about Haier HLP23E Top Load Washer
Water overflowing even the machine is not in use
Xqs60-78
I have mtr-2 dishwasher ..it is continuously showing the symbol for water filling and not going even water fully filled ..what should i do..bcz machine is not running....
You say it says water flowing. But, is it flowing? Does it overflow? If so it may be overflow switch on the bottom that got food stuff in it.
Mar 27, 2016 | Dishwashers
If water get overflow from the tub what defect it will cause to the machine
it can cause a lot of rust on the metal parts of washer and could cause wires to short out
May 22, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
The machine is not filling with water than it shows F09 and then FA on screen. Its a 6th sense and about 4 years old
Error F09 means Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Thank You
Sep 06, 2010 | Whirlpool Washing Machines
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Washing machine is overflowing, even set at low water level.
sounds like your pressure tube is not functioning correctly.
Aug 22, 2009 | Kenmore 23822 Top Load Washer
Model 110.44832 200. overflow F09 error wtr enters when off/unplg
It sounds like the water inlet valve may have jammed open , see if water still enters when machine is switched off if it does not then you probably have a short on the electronic module.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing machine
The hot/cold water fill solenoid might be stuck open.  Try banging on it lightly with a hammer and if that doesn't loosen it, replace it.
Oct 09, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Haier HLP23E Top Load Washer Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
