Question about Lanier 7228 Fuser Cleaning Roller Genuine
Job access code on lanier 7228
Copier lanier 7228 says enter Job access code---- what is this code? and how I reset this code
5 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: I have a Lanier LD 232c. Every print job we try to
Make sure that all the paper trays have the correct size and direction (portrait or landscape) in both the copier and print driver.
Posted on Jul 07, 2009
SOURCE: lanier copier ld145 locked up, code is
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Posted on Jul 29, 2009
  • 158 Answers
SOURCE: helo, I have just bought a used lanier copier
could be a failed ccd unit or it needs the charge corona replaced or the drum replaced
Posted on Oct 03, 2009
Lanier printer spc240dn engine menu nsequence
Go to the Lanier web site and download the manual. If you can't find them then contact them through the site and ask for help. See: http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Apr 01, 2015 | Lanier Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
Nov 13, 2010 | Lanier 1205 Copier
Sc 546 lanier ld
This is a fuser error code resetable by entering service mode. -Carl
Jun 10, 2010 | Lanier 1205 Copier
Data entry green light flashing. Users sending print jobs to the MP6000 are not finding their print job done. Print job history shows 0 jobs.
Make sure that a user code is not programmed in the copier itself. If it is programmed, the print driver on the computer must also contain the code.
this code can be entered in the properties menu under the "access" tab
Oct 14, 2009 | Ricoh Aficio MP1600SPF Copier
How do i print envelopes on a Lanier LP331cn laser color printer?
You should see a bypass tray near the main paper tray. On laniers it is recommended you use the bypass tray for envelopes.
when you send a print job make sure to select the bypass paper tray option
Oct 08, 2009 | Xerox WorkCentre PRO 128 Copier
I have a Lanier LD 232c. Every print job we try to send through is resulting in a paper jam. What should I look at?
Jul 06, 2009 | Lanier Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Lanier 7228 Fuser Cleaning Roller Genuine Logo
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
