Question about GE WJSR2070B Top Load Washer
Over Flowing The washing machine does not stop filling up on the super load and sometimes on the large load. When on the gentle cycle and sometimes on the normal cycle instead of coming to an end, it will click over to the cycle and start again.
  • 6,784 Answers
OK, you have two issues here. you will need a new Water level pressure switch and, the timer will need to be replaced as well.
Posted on Jun 22, 2009
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Washing machine wont quit filling during rinse cycles
if this is a top loading machine. turn it off the pull the drain hose up about six inches but do not remove it from the wall drain you should here water flowing out of the hose once the water has stopped restart you machine with the hose in the sam e position then it should fill up to the proper level and start washing. all this is provided it is not over flowing on the floor.
let me know how things go for and good luck
Sep 28, 2009 | Admiral AW22 Top Load Washer
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Machine is not filling with water.
hi
the solution is so simple, you have to open it
and clean the plastic pipe that runs from the tub to the load switch, sometimes gets dirty with detergentes and mud.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
Water keeps flowing does not stop---does not go thru cycles
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
GE WJSR2070B Top Load Washer Logo
97 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
