Question about Motorola Mobility H500 Wireless Headset
Hey, i dont know how to turn the blue tooth on.
I just got this blue tooth and i dont know how to turn it on, im pressing a bunch of buttons. and it is not comming on. but i have it on charge right now.
  • stellazhu11 Jan 30, 2008
    Hi, almost the same problem. My H-500 was perfect until one day I couldn't turn it on. The light was on when in charge, but when I also push the bottom while charging, the light will disappear.
    I guess battery problem?
    any one know how to fix it except getting a new one.
  • 4 Answers
After it holds a steady charge, try holding the power button for a few seconds. if you get a blue light (blinking or solid) then its on, obviously. holding most power buttons on bluetooth devices will put them into pairing mode, as soon as you get a solid light, you can connect it to your phone...and if you just bought the headset, you should have an instruction manual. it will tell you in there how to make it work
Posted on Nov 09, 2007
I dont know how to switch on blue tooth on my pc msi U135DX
click start. type blue tooth in search bar. then click turn on blue tooth adapter. if satisfied with my answer please rate it with the thumbs up icons.
Jul 18, 2011 | Computers & Internet
Im just 13 so i cant pay anything but i'd appreciat help, I Would Like to pair my Plantronics 220 bluetooth with my Playstation 3 but i baught it used and do not have any instructions on how
ok first you must turn the blue tooth power to on in your games system menu,then you will have to turn your blue tooth device to discovery mode,to do that most blue tooth manufactures use the power button for this feature,by holding down the power button when turning on your headset for 6 to 10 seconds it should put your device into discovery mode,then you can add or search for the blue tooth device from your game system,once it finds it,it will ask you for a pin pairing code .most blue tooth manufactures use a factory 4 digit pin pairing code,they are as follows,try them from first one because i will put them in order from most common to least common,but one of them will work,they are 0000,1234,1111,or 9999, i hope this helps you have fun gaming
Feb 26, 2011 | Radio Communications
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
for enable blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
sedngi via blue tooth ,
open any picture or ringtone and press the menu button > send using blue tooth”
receiving via blue tooth ,
Screen menu > media> press the menu button ,”Receiving using blue tooth”
Jul 17, 2010 | RIM BlackBerry 7290
I dont know the pass word for my blue tooth
If you did not yet set up a personal passcode for the blue tooth it should be 0000 or however zeros it may be. Im not exactly sure.
Apr 05, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I have a bluetooth button on my laptop but my bluetooth dont work?. when i press the button it says "no device" what shall i do ?
This laptop is blue tooth capable, but has no internal blue tooth adapter.
You will ether have to call acer and see if their help desk can answer your questions, or purchase a USB blue tooth adapter
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
Blue tooth
1, Press Comm Manager button (Right side middle)
2. Press onscreen Settings...Bluetooth
3. Press onscreen "Add new device" I tend to do this even if I have previously added a device.
4. Searching begins, if device is found follow prompts to finish install.
Sep 18, 2008 | HTC PPC-6800 Smartphone
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
HOW DO I MAKE A CALL USING THE VOICE COMMAND ON MY PHONE USING MY BLUE TOOTH
When the earpiece is in your ear the outside (blue part) is actually the multifuction key. Just press the button and say the command to make a call, and push the button again to hang up a call, it took me a day or two to figure that out too.
Hope this helps
Jul 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
143 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
