Question about Jandy Aqualink Rs4 One Touch Control System Control System
Internal red lights on aqualink rs 4 - Jandy Aqualink Rs4 One Touch Control System Control System
    Top Expert:
  • Jandy Master
  • 7,884 Answers
Shows heater is enabled
Posted on May 28, 2015
CNC65
  • 15 Answers
SOURCE: Jandy Aqualink - Rs, button control red lites on contriol panel
HAVE YOU HAD ANY LIGHTNING STRIKES?
Posted on Nov 06, 2008
  • 246 Answers
SOURCE: aqualink rs fault question
chage salt system
Posted on Aug 19, 2009
  • 246 Answers
SOURCE: Jandy aqualink RS handheld went out during
GO TO THE MAIN PANEL AND RESET THE SYSTEM
Posted on Oct 13, 2009
  • 990 Answers
SOURCE: the panel back light on myh Aqualink RS All
I don't think so but go through your menu to see if the backlight is enabled. I have never heard of one burning out unless a surge or something fried the whole unit.
Posted on Nov 03, 2009
Testimonial: "To my surprise, it was not enabled, and that was the problem. I don't know how it got disabled, because it has been on for 7 years, but. . .Thanks!"
  • 990 Answers
SOURCE: aqualink rs flow light on,
Make sure the sensor is installed in the correct direction. Their should be an arrow stamped into it somewhere to tell you the direction of water flow. Then check to be sure the filter is clean. It will slow water enough to not trip sensor.
Posted on Oct 13, 2010
I have an Aqualink RS that will not turn the pool's filter pump on either by remote or in service mode
check your jandy valves make sure they are fully open or closed they can lock your system if they are not in full closed or open mode second option is to try to turn jandy valves manually to if they are in spa mode manaully change then to pool mode or if they are in pool mode change them to spa manually on the jandy valve there is a 3 way switch this is where you can turn them manually wt we want is to send the signal back to the main control outside that the valves are in ready mode look in the main control open the door and see if there is a red light that indicates another problem if you can send me where the red light is what the red light label says it will help if you send me the aqualink model #
Oct 06, 2013 | Standard Power Center for Aqualink Rs
My handheld is stuck on waiting? What do I do?
turn all off the PDA and the aqualink then make sure the 4 pin red connector is connected inside if ok then turn aqualink on then PDA
Sep 20, 2011 | Jandy AQUALINK RS TELELINK KIT
Spa not heating up. Aqua link says Heater offline. How do we fix that?
turn off aqualink turn off heater then turn on aqualink then turn on heater it should recognize it also make sure red 4 pin connector is plugged in
Oct 11, 2010 | Jandy AQUALINK RS TELELINK KIT
I have a a rs16 and the screen says 6700 rev c what does that mean
check to see if wiring from aqualink to house isnt cut or damaged also check the red 4 pin connectors 1 inside controller make sure no wire ends touching each other or off then check the one inside the aqualink top panel
Aug 04, 2010 | Jandy AquaLink RS OneTouch RS16 Pool or...
6543 REV B01 is flashing on LCD display and all lights are blinking on indoor wallmounted control
check red 4 pin connector inside top if off or loose or wires touching or wire cut outside if ok bad control board
Sep 22, 2009 | Jandy AQUALINK RS TELELINK KIT
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Apr 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
