Question about Hoveround Teknique XHD Power Chair - Used Electric Wheelchairs
Pthe joystck frame is in a bent down position. How do I fix it
The joystick frame is bent down instead of seated straight out. How do I fix it.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 53 Answers
It would seem that the support frame is bent. Remove joystick and support from arm. Straighten support and reassemble.
Posted on Mar 05, 2015
The lock button is stuck down on my vt berlina back seat so I can't click the seat back into position. Any ideas on how to fix ? Thanks all :)
by slamming the seat back when the clip was down , you may have bent the clip
it may require pliers or lever to lift the clip back up into position
Jul 16, 2016 | Seat Cars & Trucks
Neddle hits the plate, how do i fix it ?
check that the needle is fitted correctly
check for bent needle
check for correct needle
May 23, 2015 | Sewing Machines
How to change battery on pronto m51
The Pronto M51 has two batteries in the base. The seat has to be removed to change the batteries. The M51 has had several methods of removing the seat from the base. The oldest models have a long bolt that holds the seat to a center post that sticks up from the base between the batteries. The next version has a spring loaded red handle just under the right side of the seat. If you have one of these designs you must lift the seat straight up off the center post. If not lifting straight up the seat will not come off.
The last style has the seat frame bolted to the base frame in 4 positions. Only one bolt at each corner post needs to be removed.
Oct 11, 2014 | Health & Beauty
How do I adjust the seat height on a Pronto M51 with SPJ+ Joystick
The seat height can be adjusted by removing the seat and raising up the 4 seat pillars on the bottom frame. With the pivot seat model you can raise the center post seat pillar.
Feb 12, 2014 | Invacare Pronto M51 Power Wheelchair
In game characters move automatically
This movement is because of a joystick that is broken. The joystick, while in the netural position, is sending signals to the console and thus moving the character. The only solution is to pull the joystick straight out until you hear a click. If that does not fix it, then the controller is broken.
Apr 24, 2011 | Microsoft Xbox 360 Controller
Back of front seat will not go upright ,on my 2005 ford freestyle
If the latch is working and the seat will not sit straight up and down the seat frame is likely "bent" (common problem on Ford SUVs) and cannot be fixed with normal tools. You can attempt to bend it back by pushing from the back seat, but the metal may be weak enough it may work it's way back to a reclining position. I have removed the seat cover taken seat out, bent the metal back and placed the seat back in only to have the same problem crop up. I would recommend trying to secure a used seat of the same color from an auto recycling place like Pick n Pull or if you are willing to pay more and have less hassle you can get one from a regular Auto Salvage yard.
Jul 25, 2010 | 2005 Ford Freestyle
Triple tree
Hi depends how hard you went down you can try loosening the upper and lower brackets and twist your front end into the straight position and recheck it eyeball it, if you cant get it to look straight and the forks look bent take to a mechanic and have him check it.
Some shops can straighten forks but triple clamps also can be straightened but you will have to look for a motorcycle frame shop for that service.
other than that replacement is the other option
May 03, 2010 | 2005 Honda VTX 1300 R
Joystick does not work properly with Coombat
My understanding is that Combat Flight Sim 3 doesn't like to play with anybody...been that way since they released the game....Microsoft doesn't seem to care too much about it either, I have not seen a decent patch released....but what I would do if I were you is check around the CFS3 forums and FlightSim.com and see if they have released any patches that you may not have. Remember when you apply a patch to start the game, shut it back down before installing another patch. Do this with all patches you download and install.
Sep 02, 2009 | Logitech Attack 3 Joystick
Kodak easy share self-timer
You use the the self timer as follows:
(1) Push the Menu button on back of camera
(2) Scroll through the Menu items using the small joystick located in the center of your circular selector switch, until you highlight the self timer ON/OFF area
(3) Push the small joystick straight in, like a button
(4) Use the joystick to highlight the on position
(5) Push the joystick button
(6) & just snap the picture as usual.
You will have to use the viewfinder instead of the screen to point the camera.
Hope this helps
Ron
Dec 25, 2007 | Kodak EasyShare DX7440 Digital Camera
Hoveround Teknique XHD Power Chair - Used Electric Wheelchairs Logo
54 people viewed this question
Top Hoveround Health & Beauty Experts
Lawrence Oravetz
Robin Hill
Robin Hill
Colin Taylor
Are you a Hoveround Health and Beauty Expert? Answer questions, earn points and help others
