Question about TopTeam CarsSeller
How do you bypass passlock on toyota hiace? - TopTeam CarsSeller
Where can I download a free toyota hiace 2.7 petrol 2009 owners manual?
Just google free manual for your model, make sure you put all model specs.
Jan 11, 2015 | 2007 Toyota Hi-Ace 220
Need wiring diagrams for Toyota Hiace
You can find all the wiring diagrams for Toyota Hiace in the workshop repair manual! Download it very easy from - Service Manuals.
Jan 03, 2014 | Toyota HiAce Cars & Trucks
I need to bypass my passlock sensor in a1999 express van
PASSLOCK SENSOR BYPASS
If you find the black wire and the yellow wire from the passlock sensor in the column you can solder in a 2.2 K ohm resistor and then attempt to start the car.It will stall don't turn the ignition off.Let the ignition on for ten minutes or until the theft light goes out.Turn the key off for ten seconds then attempt to start the car.If it now runs you have been successful.If it doesn't you either made a mistake or there are other problems besides the ignition lock cylinder.
Aug 24, 2013 | Megatronix - PASSLOCK-SL2 - GM Passlock...
1999 oldsmobile bravado wont start .need to bypass the passlock theft deterrent system
i think i know what the issue is. I had the same problem. There is a moduel that will bypass and fix it. You can do it yourself. They guarantee the part so i it doesnt work for some work for some reason u can send it back.. Hope this helps ya Do It Yourself GM Security bypass
Aug 18, 2013 | Megatronix - PASSLOCK-SL2 - GM Passlock...
Valve clearance 1995 toyota hiace diesel van 3l
normally .010"hot inlet and .012" hot exhaust
Apr 22, 2013 | Toyota Camry Cars & Trucks
What is the exact number for ngk spark plugs that can last on toyota hiace 3y engine
The spark plug number from Toyota Parts is 9091901059, which crosses to BPR5ES-11 for the standard plug from NGK.
If you are having problems with the plugs burning out to quickly, I would have to ask if this HiAce is a dual fuel model? Maybe they removed the LP system before you bought it, and that's causing the problems your experiencing?
Also the HiAce is an 80's minivan not an '02 Camry.
I hope this helps!
Bob
Dec 25, 2010 | 2002 Toyota Camry
Hiace alternator replace
fit a new alternator to a toyota hiace
Feb 17, 2010 | RTO Alternator/Battery Tester
Hiace Toyota
Near the foot-step on the front passenger door (open the door first!)
Jul 23, 2008 | Toyota Xtracab Cars & Trucks
TopTeam CarsSeller Logo
Top TopTeam Apps Experts
Brett Duxbury
Brett Duxbury
Are you a TopTeam App Expert? Answer questions, earn points and help others
