LG washing machine flashes warning and doesn't drain and or spin
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
If it doesn\'t drain, it won\'t spin. Therefore you have a clog in your drainage. Check the drain line first, if its not the drain line, then the filter could be clogged, or the pump itself is defective. The entry point is usually from an access panel in the rear, and it\'s not impossible to fix or replace the pump yourself, but it would require proper tools and mechanical ability. You can buy the replacement parts from the factory store or seek appliance PART stores.
If you could take your washer yourself to an LG repair facility, it would be much cheaper than a Out-Of-Warranty Home Service, but again machines aren\'t light, you need a dolly, help, and a truck, and may damage the machine during transportation. The choice is yours.
Posted on May 10, 2014
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
SOURCE: Hotpoint Aquarius WD420 washing machine won't spin and drain
same thing happened to me called engineer over flow pipe was blocked hope this helps anyone with this problem
Posted on Mar 13, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
My washing doesn't spin, It doesn't pump or spin
heatman101
Aug 12, 2011 | Washing Machines
Water doesn't drain
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
My LG WT-R807 8KG top loader washing machine will not rinse or spin I have a huge load in there at the moment. Have removed most of washing from it still won't drain. Have tried turning machine off and...
Did you try it in other cycles (delicate, permanent press, etc.)? The more symptoms - what works and doesn't allows better advice. Because right now it could be the control board, the timer, the drain pump and more.
Also you need to give us the model number off the id tag in your unit since that once keeps coming back as invalid.
Jul 14, 2011 | LG Washing Machines
Machine doesn't drain & spin, it says "OE" or sometimes some other message "E something"
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 23, 2011 | Washing Machines
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
heatman101
Oct 25, 2010 | LG WFT1071TP Top Load Washer
My LG washer will not spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Oct 07, 2010 | LG Washing Machines
The washer will not drain the water. A code O E keeps flashing...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | LG WM1812C Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
