Question about Sharp AR-M350U Copier
Buzzing sound when the device is switched on after a while found a copy of Lee's Kick Field
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 150 Answers
Please check your drumunit
Posted on May 10, 2014
Good day. I bought my Telefunken flat screen and telefunken surround sound. whenever i switch it on there is a buzzing sound. I have checked that all the speakers are in correctly.
1.Try to plug in other outlet with different circuit breaker.
Try to turn off or unplug appliances with motor (e.g. electric fan ,vacuum cleaner etc.).
2. if buzzing sound still exist isolate the ground prong of your power cord if three pin plug are used by using an adapter.
3. if buzzing sound still exist use isolation transformer.
4. if buzzing sound still exist bring your unit to service center.something wrong with your device.
Sep 09, 2017 | Televison & Video
Yamaha YSP 800 Digital Sound Projector constantly emits a low buzzing noise (even on mute). My only remedy to drown out this interference is by ramping up the volume, which sometimes actually fixes the...
Do you have any other nearby devices that emit radio frequencies like a wireless router or a cell phone? I have had issues with buzzing on some of my speakers when my cellphone was nearby.
Oct 15, 2013 | Audio Players & Recorders
I turn on the power and get just a buzzing noise. The keyboard does not work at all. The power light is on but no sound from the keyboard other than a buzzing sound.
normally a buzzing sound means a grounding problem, or a component has failed, unless you have the proper equipment to check these items,, your going to have to take it to a shop that does, sorry I know thats not what you wanted to hear,, but heres a hint, Ive found that a shop that deals in instruments and sound devices charges a lot, I have found a TV repair shop in my town, that can check my band equipment,, and its much cheaper, and I usually get the stuff back much quicker too
Sep 01, 2011 | Akai Music
Subwoofer suddenly making buzzing sound but is not hooked up to anything,fuses arent blown and its been in the same spot for a few years and never had a problem.happened suddenly.moved it to another spot...
hi pls make sure that there isn't any other magnetic or electromagnetic device near the speakers because due to induction ur speakers magnetic field gets distorted which makes that buzzing sound irrespective of no fault wiring may be this may help u or see that the wiring near the woofers speaker magnet is attached strongly so that it doesn't distorts any more was this helpful if yes pls vote
with warm regards - bonefirediv
Mar 25, 2011 | Car Audio & Video
Buzzing noise when i turn off Garmin 60CSx
This problem is Mac OSX related and can be solved using Cleaneject http://www.javawa.nl/cleaneject_en.html
The OSX operating system creates several invisible files and folders on USB-disks, camera's and GPS devices and the Garmin GPS devices can't cope with these invisible files and folders.
Cleaneject erases the invisible files and folders.
Feb 27, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Problem with Samsung SyncMaster 226BW
Click the top button on the side of the monitor to open the monitor's settings. In the "Picture" Settings, scroll down to "MagicBright" and open those settings. Chances are you have it set to "Dynamic Contrast". Switch that up to any of the other settings and then it won't try to adjust the gamma based on what is on the screen.
Hope this helps, I struggled with the same problem for quite a while until I found this setting.
Feb 19, 2009 | Samsung 226BW Monitor
Makes a loud buzzing sound when washing
This buzzing sound can be from a couple things. A lose a lose kick/access panel when the motor and pump is in operation can cause a slight vibrating noise. Try tightening securing the dishwasher and kick/access panel.
Second, (most likely) their can be an obstruction or debris in the water pump. You may see a plastic grid (4" x 6"; filter like) in the right rear of your dishwasher; Try removing the grid (1 or 2 screws 1/4"/cross tip), then use a dry-vac to remove any debris. *
Safety: As a beginning, please remember to perform the repairs with the power-off and ensure you have water in the dishwasher before restarting the water pump cycle (the water-pump can become damaged while dry-spinning and water enters the pump suddenly)
Jan 26, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Motor won't start, makes buzzing sound, motor won't kick in
Sonds to me like something is stuck in the impellaer
did a glass break in the machine lately or possible some food got stuck worst case the motor start capacitor has given up the ghost so to speak.
Jan 21, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Light won't light in fridge, circuit is buzzing
Pull the switch at the front door. Take off the 2 wires and put them together. No light then, Live chat me. If this has proven help, please list as fixya
Jan 10, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Relay
Ok, I did more research you are right they don't have a relay, just the I thought a 20A fuse, If you have 12V at the light socket. Then it sounds like you have a ground problem. Check your grounds make sure there isn't corrosion etc. Clean them up I think this may be your issue. You changed the switch so that is the only other thing that would usually cause that. Check your grounds and let me know.
Thanks,
Lee
Jul 11, 2008 | 1991 Jeep Cherokee Limited
Sharp AR-M350U Copier Logo
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
