Question about Mitel Superconsole 1000
Screen says no communication, software download required, Boot 1.3. Console will not boot up
Console is off line, have tried un plugging and plugging but same results.
  • Stanley Nodland
    Stanley Nodland Mar 24, 2015
    Yes, have found a solution to this issue. The console is defective and needs to be repaired internally.
    Try these folks here:
    Regards,
    Brenda Thornton
    iStream Communications
    570-714-6336 x211
    www.istreamcom.com
    Buy/Sell/Repair/Refurbish all MITEL
    New Friend:
I am currently having this issue. Did you ever find out the answer?
Posted on Mar 20, 2015
Testimonial: "Yes, I did find a solution to this issue. The console is defective and needs to be repaired. Try these folks here: Regards, Brenda Thornton iStream Communications 570-714-6336 x211 www.istreamcom.com Buy/Sell/Repair/Refurbish all MITEL"
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Boots up but goes to the xp screen and then shuts down and restarts. what do i do?
You will need your XP CD to run a Repair install.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will need to press enter to setup Windows XP.
3. To setup Windows XP now and Repair Install, press ENTER. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read the fix at the end of this post.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
If you don't have an option to repair, try this:
1. Boot with XP CD.
2. Press R to load the Recovery Console.
3. Login to the Recovery Console using your Admin password if needed.
4. Type bootcfg
5. This should fix any boot.ini errors causing setup not to see the XP installation.
6. Try the repair install again.
If the Repair is still not an option, try the following:
1. Boot with XP CD.
4. If the CD letter is K: give these commands
* copy K:\i386\ntldr C:\
* copy K:\i386\ntdetect.com C:\
While still in the Recovery Console, try this as well:
1. Type: attrib -h -r -s C:\boot.ini del C:\boot.ini
2. Type: BootCfg /Rebuild
3. Now Restart and try the Repair Install again.
Feb 23, 2011 | Gateway 704GE PC Desktop
T42 gets message"NTLDR" not available. Tried to
Don't try loading windows with out fixing the NTLDR...Try this simple steps in recovery console,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
  • Then rebuild the boot configuration boot.ini file by
    Attrib -H -R -S C:\boot.ini (if not found skip the next line)
    DEL C:\boot.ini
    BootCfg /Rebuild
    Note:
    Do not use the repair option in the recovery console.
    Or, if you can get into XP, even safe mode, you can arrange to bypass the
    password by the following registry change:
    Click on Start then click run and type Regedit. Navigate to the key mentioned below,
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Setup\RecoveryConsole
    Set the DWORD Security Level value to 1
Hope this helps
Dec 27, 2010 | IBM ThinkPad T42 Notebook
Can i386 unidrv.hlp for xp pro sp 3 be downloaded from Microsoft?
  1. Insert the Windows XP startup disk in the floppy disk drive, or insert the Windows XP CD in the CD drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD drive if you are prompted to do this.
  3. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  4. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  5. When you are prompted, type the Administrator password. If the Administrator password is blank, press ENTER.
  6. At the Recovery Console command prompt, type the following lines. Press ENTER after each line. cd system32
    ren ntkrnlpa.exe ntkrnlpa.old
    ren ntoskrnl.exe ntoskrnl.old
    cd "c:\windows\driver cache\i386"
    expand sp2.cab -F:ntkrpamp.exe c:\windows\system32
    expand sp2.cab -F:ntkrnlmp.exe c:\windows\system32
    cd c:\windows\system32
    ren ntkrpamp.exe ntkrnlpa.exe
    ren ntkrnlmp.exe ntoskrnl.exe
  7. Type exit to quit Recovery Console. Your computer will restart.
Or go to http://www.ventrilo.com/dlprod.php?id=1 and click on agree.
Nov 03, 2010 | Epson Stylus Photo EX InkJet Printer
Ntldr is compressed
An NTLDR is compressed error is pretty easy to fix(much better then NTLDR is missing errors!).
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Feb 25, 2010 | Microsoft Windows XP Home Edition
I have a emachines w 3107 I tried to use the system recoverey disk. I went through the whole process, Then when it re boots a error says NTLDR is compressed press alr cont del , And I get the same error...
5. Now you should be at the command prompt and ready to repair the ntldr file!
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 08, 2009 | E-Machines eMachines Desktop PC
NTRL is compressed Press Ctrl+Alt+Del to restart
cd \
attrib -c ntldr
exit
Please rate this fixya
Jan 26, 2009 | Gateway GT5220 PC Desktop
Blue screen of death
post_old.gif The error is a software error in the NT File System which is the format that you have installed on your computer. The repair is to boot to the CD installation disc or a copy of the boot discd (K)s and open the repair console to repair the file system....since you are unable to boot to the repair console then your only option is to reformat and reinstall....I hope that you have your system backed up!
Jan 11, 2009 | Dell Inspiron 4100 Notebook
Deleted dll
BOOT FROM YOUR WINDOWS DISC AND CHOSE OPTION RECOVERY CONSOLE AND USE THE GUIDED HELP...BUT FIRST DOWNLOAD THE MISSING FILE AND COPY IT TO WINDOWS 32 SYSTEM FILE FOLDER.RICHARDM69
Dec 01, 2008 | Dell Dimension 8100 PC Desktop
NV-U70 Won't load past INSTALLATION screen
I have had a problem like yours and yes there is software that will get you back in but you should try Windows XP Startup disk or Windows XP CD to use Recovery Console. When either of these two is inserted, restart your computer. When the "Welcome to Setup" screen appears, press R to start the Recovery Console. Once the Recovery Console is open, type your Administrator password (blank by default) and input fixmbr to get MBR fixed.
Note that the fixmbr command may damage your partition table (part of MBR) if a hardware problem exists. You may also create inaccessible partitions by this command. You are highly recommended to backup your data before you use this fixmbr command.Ok if you dont have the disks here is a list of software that you can use. www.Spotmau BootSuite .com I have used this program and its very good I will also give you a few free ones that you might like to try http://www.lazesoft.com/lazesoft-recovery-suite-free.html ............. http://ccm.net/download/download-1221-ultimate-boot-cd ...........
http://download.cnet.com/Windows-Boot-Genius/3000-2094_4-75827488.html...... if these are of no help then google search using" boot disk software" or: boot disk software free"
Aug 07, 2017 | Sony nav-u NV-U70 GPS Receiver
Mitel Superconsole 1000 Logo
225 people viewed this question
Top Mitel Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Mitel Radio Communication Expert? Answer questions, earn points and help others
