Question about LG LDF9810ST Built-in Dishwasher
I have a prima LPR 450 dishwasher, the light is on but I cannot select a program
  • 641 Answers
If the unit is not operating, then it will require service. To make service arrangements, you may either contact our Customer Interactive Center at 800-243-0000, or you can check our Repair Provider Lookup on our website, at http://www.lg.com/us/support/repair
Posted on May 10, 2014
2 Suggested Answers
SOURCE: Hi, I bought a second hand prima lpr 450
Hi, thanks for your help. We have solved the problem and the dishwasher is working! Thanks.
Posted on Aug 20, 2009
Unable to start the oven prima lpr9023
Hi i have just fitted my new prima double oven Type FCSM9 Model LPR 9030 and the main oven will not work, and i can not set the clock. it came without instructions. can you please help
Nov 10, 2009 | Ovens
No lights on prima lpr 600 dishwasher just keeps filling up with water not draining
When there is no light at all, and machine is stuck with inlet valve open from start, then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
Mar 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Continual beeping
I've had this problem a couple of times.. I filled a pan of water, poured it into the bottom, turned it on and made sure the pump was actually pumping.
I then unscrewed the dishwasher from the housing and turned off the water and electric, removed the outlet and gently rocked the dishwasher to try and dislodge anything inside the pipes.
Worked twice now anyway!
Hope this helps :)
Dec 13, 2008 | Dishwashers
Seem to have an earth fault with a prima lpr 450 dishwasher runs for about 15 min then trips our electric.It did a few times from new (about 3 years old now) then stopped doing it, now does it nearly every...
Hello gcsounds,
If I understand your problem correctly, it appears that you have a ground fault ( or earth fault) that is causing your breaker to trip. I am assuming ( but don't know for sure ) that your dishwasher is hard wired into a junction box and that junction box is fed power from your circuit breaker panel. I am also assuming that the circuit breaker is either a Ground Fault Interupt ( GFI ) or standard type and that breaker is what you are saying is tripping with every wash cycle. There are some details that need to be filled in for me by you in order for me to fully understand your wiring scheme and suggest ways to resolve your problem. First off, can you provide details on how your dishwasher is wired ( as I suggested above or other) and secondly, what voltage are you running it at? If you are in the US then in all probability you are running your dishwasher at 120VAC @ 60 hz but if you aren't then please elaborate. Once I have that information, I may be able to assist diagnosing and resolving your problem.
Regards,
Rick
Nov 22, 2008 | Dishwashers
Prima lpr 600
Sounds like something may be blocking the pump, causing overload -- may need a service call.
Feb 10, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Prima LPR 600
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more.  Try this.
Dec 27, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Prima LPR600
my prima LPR intregated dishwasher just not playing ball, has not been washing properly and had a continuous flashing and beeping fault, we cleaned out the filers and the arms which seemed to help the beeping problem but now have a fault where at the end of the cylcle its now showing another fault where it flashes 4 times but beeping has stopped what seems to be the problem and how do we fix ?
Oct 17, 2007 | Dishwashers
Prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Oct 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
LG LDF9810ST Built-in Dishwasher Logo
159 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
