Question about RCA 32V420T 32" TV
Same exact problems! would be curious about this transformer...
My Hartke A100 has a problem, no power, the problem is transformer. what is the exact volt of transformer A100 hartke? than you
Transformers don't often fail. I have heard that some of these have a thermal fuse in them and they sometimes open. If you can get to the fuse in the windings, you can replace it and save the transformer. The fuses look like a silver tube about 5/8 inch long and 3/16 inch diameter with a lead out each end, They are marked with the temp they open and are a one-shot thing that have to be replaced.
May 30, 2011 | Hartke A100 Combo Bass Amp
82 suzuki gn250 bike runs with choke on , second chokes of bike dies. more throttle while choke on bike dies ????????????
sorry, dont have a solution, but was curious if you ever figured this problem out, i have the exact same issue
Aug 23, 2010 | 1986 Suzuki Rg 250
I have a Th-46pz85u panasonic plasma tv that is blinking the power light 10 times. I was curious to see what the replacement part is to fix that problem. I have the Panasonic error codes and that error...
Yes,this codes is a 100% correct is ur power supply board.U searches all around the power supply board and it supporting boards for those leakages gases capacitors?These capacitors alway have bulges on it top or puff on it top.Replaced these bad capacitors,u will get ur power voltages stable and ur power supply board will work.Not,than one or more of ur power transformers have a shorted power pins legs.The power transformers,coil is dead.The transformer must be replaced.
May 03, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Exactly the same thing...
the phone is not dead it needs to be reflash n eprom to correct this issue.
Jun 07, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Curious
Try to descale your machine, if there are calcium in the boiler then the coffee will have wrong temperature and tast bad.
Aug 06, 2008 | Saeco Aroma Espresso Machine
Cost of transformer?
If its the HV Transformer ( flyback) Its about 70.00 the other transformers are quite cheaper
Jun 21, 2008 | Hitachi 57F500 57" Rear Projection...
Doesnt do anything
It's the transformer. Match the new one as close as possible to the old if not exact.
Apr 29, 2008 | Goodman GMS90703BXA Heater
Razr v3- no service message
take it to a mobile service center and have them service the phone for you..
Mar 11, 2008 | Motorola Mobility RAZR V3
No picture High pitch squeal RCA F36650
Confirm service # from back of set = F36650 YX01..........
Transformer red HV lead attaches to CRT & Horiz output
xistor is on heatsink next to transformer = 2SC5148 .........
Rca part # 257805 or ASTI 2078 and 237470 xistor............
Do not use a generic transistor = name brand only............T.
Please rate this solution..............
Nov 12, 2007 | RCA F36650 36" TV
RCA 32V420T 32" TV Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
