My projector Is stuck in USB mode - Office Equipment & Supplies
3d mode auto mode not working for ps4 on projector
There should be a 2D/3D button for the projector. Sometimes they get stuck on 2D and need to be manually switched.
Nov 18, 2014 | Office Equipment & Supplies
Cannot Connect My Compaq Presario CQ57 to my Epson Powerlite S4 LCD Projector! Help! Please?
The USB port in the projector is only for Optional Mouse to srcroll down the menu of the projector. Its not ment for the Video connectivity. You have to use 15 pin VGA cable to interconnect the PC and the projector then only you will get the video.
Here i have added the link for the user manual of the projector. Check out page number 30 of the manual.
Ajin
Feb 10, 2012 | Epson Office Equipment & Supplies
I cannot seem to link up my projector and laptop computer
Assuming that you have all the connections between the laptop and the projector already performed, you should check in you laptop's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
If even with these indications you are still not able to make your laptop show its information through the projector, please send us more details on how you connected your laptop to the projector, as well as the brand and model of your laptop.
Hope this information can help you!
Mar 09, 2011 | Vivitek D825MS Projector
My Sony Data Projector VPL CS6 is stuck in emergency mode, can it be reversed.
I tried the emergency mode and recovered the powered mode. just make sure you can turn the adjuster ( that big grey plastic screw) freely and leave it that way (don't tighten it or put the **** back in). try turning it on. works for me..
Feb 23, 2010 | Sony VPL CS6 Multimedia Projector
Sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Dec 04, 2009 | Sharp XR-1X Multimedia Projector
I can't project my image from my laptop to the projector..
A usb cable will not work that way--on your projector, it's used for data...you need to obtain a monitor cable which will plug into the vga connector on the laptop and into the connector on the projector (rgb in 1) or (rgb in 2) If you use the #2 rgb input, make sure the button IS NOT pushed in! If it is, the projector will be switched to OUTPUT mode on the #2 connector. Also, on the laptop, normal operation is "laptop only"...when you push the <alt F4> buttons, it should then switch to "laptop + external display(projector)", another <alt F4> push will give "external display only" mode. Then, another push will return you back to "laptop only". NOTE: Sometimes, you have to turn on the projector first, then immediately turn on the laptop--not to get technical but different equipment can get finicky about syncing up...just something to be aware of...
Aug 31, 2009 | Hitachi CP-X250 Multimedia Projector
Acer 4736 compatibility with eb-s6 projector in usb display mode.
Check the Microsoft knowledge base for a "workaround" for this issue.
Try doing a search for "device not recognized" there should be several steps to correct this issue. However this may be due to compatibility with your projector and the usb port drivers. Contact the manufacturer or go to his website for driver and usb information on your Projector ability to connect to your Acer. Good luck!
Aug 13, 2009 | Computers & Internet
Sony vaio stuck in presentation mode
Right click on your desktop, go to display and change your resolution to one that is more pleasing.
Mar 24, 2009 | Sony VAIO VGN-FE770G Notebook
I want spesifications of LG LCD Projector model DS325-JD
Model : DS325 LG's Professional Advanced Data Projector e2008031093271.jpgMain Spec
- 0.55" DMD
- Native SVGA (800x600)
- 2500 ANSI Lumens
- Ultra Light Weight 1.45Kg
- Contrast 2000:1
e2008031093271.jpgAdd-on Value Features
- 3 Level Brightness mode
- Composite, Component, S-Video, USB
- HD ready
- 1W Mono Speaker
- Remote Control
Dec 15, 2008 | Computers & Internet
Presentation mode is off...
Hi there
You cannot hook up a PC & Projector with just a USB cable , you have to use a VGA cable for signal ( picture )
The USB cable is just to use the scroll up or down function from the standard remote controll when doing a presentation.
Apr 14, 2008 | Hitachi CP-X260W Multimedia Projector
jasbo
jasbo
