Question about Vacuums
My Bissil Pro Heat works great except when I push the shampooer it sounds n feels like the front drags accros the floor like it is catching on something and is not gliding like it should smoothly n properly over the carpet. What should I check? Or is there anything I can do to get it to run properly?
  • Vacuums Master
  • 1,321 Answers
Check to see if there is a broken or cracked part on the plastic on the front or the bottom of the machine where it glides across the carpet. Usually it is the part where the machine sucks the dirty water up in to the machine that is broken and catches on the carpet. If you need one of these parts I have them new and pre-owned.
Posted on May 10, 2014
chrispurs1
  • 372 Answers
SOURCE: suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Posted on Nov 19, 2007
  • 126 Answers
SOURCE: need help putting my bissell carpet shampooer back together
I don't know how to advise you on this. The Bissell is pretty complicated when you take the hood off. Under there is a number of things that must be in place correctly to replace the hood. There is a small plastic "rod" with an "o" ring on it that controls the shampoo mixture and that has to be positioned right to replace the hood. You may have to take the machine to an experienced shop to have it re-assembled. I don't think I can tell you all the little things you have to do to re-assemble it yourself.
In regards to the elevator, there are two arms that lift the brush off the floor when the handle is put in the upright position. This is so the brush will rotate freely while you use the hose. These arms break quite easily and are available from any repair depot in a set.
You may be able to get a schematic diagram from a warranty service dealer. They have a special "dealer only" web site that they can access to get repair and parts info. Usually, they can e-mail or fax you information if you're really nice to them. Smile when you're on the phone. :)
Posted on Jan 27, 2008
reddevil6
  • 1673 Answers
SOURCE: bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Posted on Jun 17, 2008
SOURCE: Need a user manual for the Electrolux Floor Pro Rug Shampooer
Found a manual on the internet so do not need any assistance.
Posted on Mar 20, 2009
  • 37 Answers
SOURCE: My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Posted on Aug 29, 2009
Testimonial: "many thanks for your help l will take a look at the shampooer and if I feel I know what Im doing I'll have a go myself if not I will contact service "
I just bought a bissell pro heat shampooer it worked the first time now it won't **** up water
go please to the web page:http://www.bissell.com/maintenance-tips/
and proceed according with the videos for troubleshooting+fix it.
God bless you
Aug 02, 2012 | Vacuums
I need a users manuel for my Epic floor pro floor shampooer model # S1058
The manual can be found at http://www.aerusvacuums.com/support/manuals/index.cfm.
You can go to either "Current Modesl" or "Older Models" and select the Lux Floor Pro. These are basically the same machines as yours.
Jun 21, 2010 | Electrolux Floor Pro Vacuum
Broken floor piece.
I don't think so, but check the manuals link...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jan 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Mar 19, 2009 | Electrolux Vacuums
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not rolling properly
Sounds like the front of the nooze isn't seated with the base, or the clear window is loose. The base has a catch the lock the top housing together,
Jan 06, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
