Question about Epson Stylus CX6600 All-In-One InkJet Printer
How do I print an enlarged copy of a document on the epson stylus nx625
SOURCE:
jacklee366
  • 541 Answers
SOURCE: my r230 photo printer epson stylus was sevice required unable to print and see your printer documents
this means the wast pads are full and the printer needs to be reset this is a link for the software needed to reset your ptinter http://www.ssclg.com/epsone.shtml
pla dont forget to rate
Posted on Dec 01, 2008
  • 15 Answers
SOURCE: CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
Posted on Mar 01, 2009
  • 700 Answers
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: Epson stylus photo rx420
Move envelope/A4 lever near paper output tray until the letter L registers on display. Print in this mode and you should have full page printed.
Posted on Oct 21, 2009
SOURCE: service required for EPSON STYLUS R230
red light bhoth blinking
Posted on Dec 28, 2009
How to enlarge print? enlarge font? NX230
Any changes to font size, color, etc is controlled by the software in your computer, that you are creating or viewing the document in - if you are just viewing a document in something like Acrobat, you cannot change the type size- your only option is to "blow" up the output, but it might be bigger than what will fit on one page of printer paper
Aug 31, 2012 | Epson Stylus NX230 Small-in-One Color...
How can I scan a document, enlarge the print and send it as an attachment to an email?
Generally, when you scan a document, it is a photo of the item. You can use a photo editor to enlarge then save the enlargement, once done, file, send to, email recipient, this should attach the scan as an attachment
Oct 20, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus NX300. I send a FAX and the folks on
check first if your printer can copy well. try to photocopy a document. and if it copies well, that means, its a problem on the part of the receiever, if it does not copy well, that means the scanner of your unit has a problem.
Feb 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
How do I enlarge the print on an Epson Stylus CX9400 fax series?
the printing wizard it has the size choice ...but the actual size its established by the limitations of the printer ..anyway all documents may be re-sized in the computer and than printed...even in pieces and reattached after if the printer supports only A4 paper maximum
Sep 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
I cant enlarge a photo copy on my Epsom printer TX100
While printing go to options before pressing print button. There choose size you will find your solution there. You can select printing sizes there.
Mar 12, 2009 | Epson Office Equipment & Supplies
Feb 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus cx7400 wont print but one copy at a time
Epson Stylus S20, when I alter number of copies required from 1 to say, 8, it prints only ONE. Why? [email protected]
Jan 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
