Where can i get manual for radio shack SSM-8030 audio mixer?
How can I adjust the relative gain between Left and Right channels?
  • Greg Kendall
    Greg Kendall May 10, 2014
    Unfortunately all the sliders, and gain controls take effect on both L and R channels. There are no external controls where I can adjust one channel. The problem is that a common signal applied to both L & R channels of any of the inputs has a 3db lower output on one channel. I would ideally like to get a circuit diagram to see if there are any internal channel gain adjustments.
    Genius:
  • 1,552 Answers
Does your audio-mixer have "pan" control on each input channel?
Pan the channel from "100%-left" to "100%-right".
What about the main output from the mixer?
Does it feed into a stereo-mixer?
Can you adjust the gain on either the left or right channel?
Posted on May 10, 2014
No sound on left channel on home stereo optimus sta-795 will changing fuse out restore sound
Not likely! Suggest swapping input connection, red RCA connector to white and white to red and see if problem swaps speakers.
If still left channel bad swap speakers left to right see if problem follows speaker.
Check balance adjustment and confirm that it is set to the middle!
Check all other inputs and confirm always no left output.
The goal is to confirm that the left channel is defective!
The service manual is MS3102101 would normally be available from Radio Shack.
Check for defective capacitors or failed solder joints on the PC board. These units are repairable even by DIY however replacement recievers are relatively inexpensive.
Hope this helps?
Nov 20, 2016 | Optimus Audio Players & Recorders
Little or no sound
Have you tried another source into the same input on the mixer and does this also come through quiet? Have you checked the gain for the channel(s) you are using? Have you tried a different wire for the connection as well as different source? Is it on all channels? have you tried a different amp?
Feb 25, 2014 | Behringer Xenyx 502 Audio Live Music Mixer...
My optimus ssm-50 does not fade in or fade out
It is probably a bad slide pot. Try this Radio Shack link for help and the manual: http://support.radioshack.com/support_audio/40119.htm
This link is the manual but it did not work for me. http://support.radioshack.com/support_audio/doc62/62615.pdf
Aug 26, 2013 | Audio Players & Recorders
I have a Behringer 1002 mixer. Applying 0 dBu unbalanced to the input I need the -10/+4 control in its most sensitive position to acheive 0 db out with the main output control set at 0 dB. Is this cor
Depends on the input you are using. First you need to calibrate signal coming in with the Gain attenuation knob. Setting this prior to adjusting your channel output volume should calibrate the signal so when the channel volume knob is set to 0 and the Main volume is set to 0, the meters should indicate a true 0 reading.Not setting the Gain correctly will affect this. On the 1/4" channel inputs, you have less adjustment and may have to adjust the item you are plugging in from its source. If you are having issues with high gain, chances are it could be a cable issue, or something from the source itself.
Jun 06, 2012 | Behringer 1002 10 Input 2 Bus Mixer
Pls send me a connection diagram of how to connect my dbx 215 graphic equalizers to a powered mixer
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/dbx2SeriesManualA2.pdf It's all in there. Here is a little extra guidance. if you are getting your left and right channels out through RCA you will need a RCA to 1/4 in adapter Radio Shack carries them relatively cheap. If it's already 1/4 or XLR skip this Left goes into Left in, Right goes into Right in. Then work backwards Right comes out of Right out, Left comes out of Left out. channel 1(left in) and Channel 2(right in) of your powered mixer. you should be set.
Good Luck, Cody J.
Dec 16, 2010 | DBX -215 Home Equalizer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
No problem would just like t know if this mixer will drive more than one amp at a time
Well, mixers don't "drive" amps, but you can supply a signal to more than one amp from most mixers. You're probably already using the "main" outputs, but you're going to have some other outputs that you can use too.
Look on the back of the mixer for "tape out" or "monitor out." You might have to get some adaptors ($10 at radio shack) to go from RCA to 1/4 inch maybe, and you might have a separate gain adjustment, too.
Nov 10, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
RADIO SHACK TRC-447
A number of things....faulty speaker (you can scratch test this with a torch 1.5 volt cell....cell pos goes to 1 speaker terminal
and cel neg goes to other speaker terminal..you can conect it any way around with flying leads from the cell...just keep touching the terminal with one flying lead...you will hear a scratching sound in the speaker) have your mike checked...test the tx/rx relay on the circuit board for tx/rx switching, or, a failed
driver transister in the output stage....the list is many
Cheers flyingfox@people.net.au
Jun 21, 2008 | Radio Shack TRC-447 CB Radio
Connecting
please follow me:-1-bring two audio spliters(split one audio to two audios(from near radio shack).2-connect single end of both one to the right out of dvd and the other to the leftout.now you have 4 jacks.
two audio right channel.
two audio left channel.
connect one right and one left to amplifier input right and left.
connect one right and one left to lcd screen audio in.
enjoy it.
Jan 28, 2008 | Audio Players & Recorders
Powered mixer gain
use good brand contact cleaner from radio shack or other electronics store and apply spray in the slider of defective channel and move each slider up and down many times.by the way check cabels which feed bad channel for a good condition and test these channel with the good cabel of good channel to confirm that the trouble in channel itself.after all if it is hopeless pass the mixer to service center to fix it.
Oct 11, 2007 | Audio Players & Recorders
186 people viewed this question
 Grubhead
Grubhead
