Question about Coffee Makers & Espresso Machines
Cooks coffee pot replacement parts
I have a Cook's coffee pot which works good, but the handles on the filter basket came off right after i purchased at penney's in santa rosa ca. Actually only one side of the handle. Model CM4260-A 12 cup; item 22087. purchased about 2 months ago. This is still under warranty. How should I handle replacement. thank you barbara crtsmjc@aol.com
  • 30 Answers
SOURCE: filter basket
You can find ODC325s on ebay just for parts since the heating element is shot. I don't believe those parts are for sale anymore.
Posted on Jun 26, 2008
SOURCE: MODEL CM202 (COOK ESSENTIALS)
Contact Heather at Select Brands. I ordered replacement carafes for our office CM202 dual coffee maker. It took about a month to get them, so be patient. I believe they make an order when enough folks get on the list for replacements.
marketing@selectbrands.com
Heather's email to me last year (Aug 07):
Those carafes are 15$ and that includes s&h. We take MasterCard/Visa over the phone or via e-mail. However, they are on backorder right now. Please give me your name/address/phone number/how many carafes you are interested in and I’ll put you on the call back list and I’ll contact you once they become available
Heather Seute
Customer Service Manager
913.663.4500 x 221
Posted on Aug 14, 2008
  • 33 Answers
SOURCE: basket and perk tube
Sure is
see if you can locate the model somewhere on in it
http://www.abtecparts.com/westbend.htm
Try this to order all of your part needs !
eric
Posted on Feb 16, 2009
SOURCE: need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Posted on Jul 29, 2009
coffeefixer
  • 53 Answers
SOURCE: I am seeking to purchase
I looked at all the suppliers i deal with and cant find anything. you might try specialty kitchen stores and find one thats close.
Posted on Sep 06, 2011
One Pot Cooker does not cook
Is this a slow cooker? If so , it doesn't get hot, you cook casseroles in it for 8/10 hours, prep all your veg and meat, saute in a deep frying pan, add stock or a casserole mix, bring up to boil, tip into your cooker, switched to med/hot and leave, the ides is that you do prep night before and cook overnight, or first thing in morning and leave to cook all day
Jun 15, 2012 | Coffee Makers & Espresso Machines
How do I stop the oily residue in my brewd cup of coffee? The coffee maker is new. The residue is not from our filtered water.
Thoroughly wash the pot and the basket with a good oil/grease remover (detergent) such as DAWN dishwashing liquid.
Then run White Vineger/Water (50/50) mix through the coffee maker TWICE, with the basket and pot in place. (NO coffee, nothing in the basket)
DO NOT RUN any detergent or soap through the coffeemaker at any time.
Then, run straight water through the coffee maker TWICE (no coffee, basket empty)
Then wash the pot and basket out AGAIN with a good detergent.
This will remove any residue that is in the coffeeemaker from the factory.
As coffee brews, there IS a slight amount of oil that is produced. The coffee itself has oils in it, and is part of its flavor, and freshly brewed coffee will have a slight oil residue.
Jun 24, 2011 | Rival Coffee Makers & Espresso Machines
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
Kenmore Elite coffee maker Model # 100.9101670A Is this model on a recall? How can I get a manual for it? And what is the filter reset button?
I have a manual with mine and as far as "recall" goes on this model, I've not found anything recalling this particular model...<br /> <br /> The most important thing in the manual, that I have found, is how to clean and change the filter. If all else fails unplug the pot for 10-15 seconds; replug it...this resets it...(if it ever acts up, do this; it helps)<br /> <br /> The filter reset button: Your coffeepot should flash a small message stating: "change filter and clean" To do this you first, turn off the pot, remove filter~(the filter is in a long thin black plastic thing and the filter cover simply snaps and pulls apart to expose the charcoil filter; Remove the Filter, then fill the coffee pot with 7 cups of vinegar plus 7 cups cold water; Place a paper type regular coffee filter in the brew basket, or a thin paper towel works well too~(This traps and holds particles that get trapped inside the pot)<br /> <br /> Before brewing; PLEASE NOTE, brew the first pot of vinegar/water mixture only HALF WAY then TURN OFF and let it sit for a good 15 minutes to soften any deposits...<br /> Turn the pot BACK ON and brew the remaining solution. When brew stops turn OFF coffee pot, empty the solution, and discard the paper filter...<br /> <br /> Refill reservoir with cold water and turn ON; you may want to dump this and refill with more cold water to ensure the vinegar taste/smell is gone...<br /> <br /> Now, wash the brew basket and the glass pot...Open the black skiny Water Filter and replace with a new charcoil filter...Put Filter back in pot...fill brew basket with coffee and brew some mighty fine tasting coffee!!! Hope this helps....Good Luck
Jun 29, 2010 | Coffee Makers & Espresso Machines
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need to replace filter basket drip spout rubber ring
Jul 28, 2009 | Coffee Makers & Espresso Machines
Bunn coffee pot blows water out top of basket
Check the grind on the coffee, brew a pot without coffee and if it overflows, then the machine has a problem. If it doesn't then try a coarser grind on the coffee.
Jun 14, 2009 | Bunn Coffee Pots: Thermal Carafe
I have a cooks coffe maker (from JcPenny) my coffe
Wal-Mart,  BI-mart, Target, K-mart those kinda stores usally have them. or you can find the cook web site and try that.
Apr 20, 2009 | Cook's Essentials Cooks Essentials Arome...
Heather Seute
913.663.4500 x 221
Aug 06, 2008 | Cook's Essentials Coffee Makers & Espresso...
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
