Question about Zebra GX420t Thermal Printer
Zebra Gx420t realign label maker - Zebra GX420t Thermal Printer
5 Suggested Answers
SOURCE: ZEBRA TLP 2824 LABEL MAKER PROBLEMS
I've had this problem. I changed the margins and it solved it.
Posted on Jun 09, 2009
  • 32 Answers
SOURCE: Zebra S4M label printer
Check the drive belt. It might be missing a tooth if the printer is older. I can assist if you want to check this.
Posted on Oct 27, 2009
  • 15 Answers
SOURCE: Stripe S600 Thermal Label Printer: how to load zebra stripe printer labels...
CLICK HERE to download the full user manual from Zebra. If the link doesn't work, go to Zebra.com, click Resource Library at the top of the screen, then click MANUAL. Choose your model number then follow the prompts.
Posted on Jun 07, 2010
  • 254 Answers
SOURCE: zebra label printer printing on
have you checked the size of the label in your driver?
You may be simply sending the information on two pages!
Posted on Aug 12, 2011
How do i adjust the tear off point for a label?
think this is done when you print it
? how long is a bit of string?? as long as you need is the answer
so load or download and load the software for it
and work from its templates
Mar 05, 2015 | Zebra GX420t Thermal Printer
Zebra printing continuously problem
disconnect printer from computer and power on again. at driver chech if still jobs there and clear buffer. at printer, if still printing whithout connested its becase it still have information to print. just reset printer to factory default or let job to finish.
Mar 18, 2014 | Zebra GX420t Thermal Printer
Gx420t printing blank configuration pages
Could be faulty printhead. OR ribbon is put in the other way around. hard to say. It would be better off call the service technician.
Sep 27, 2013 | Zebra GX420t Thermal Printer
Printer printing in batches, delay when printing
Desktop printer has limited memory. It's all depending on how many information you put in the label. Your communication cable used? USB or serial? what type of fonts you use
Sep 03, 2013 | Zebra GX420t Thermal Printer
We just got 2 Zebra GX 420t Thermal Printers for less than 4 month but one seems fading out the labels , some words are missing on the label, we have to clean it everytime it happened , please , any tips...
you need to adjust the print head and perform a calibration.
here is the user manual:
http://tinyurl.com/4l3xghr
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 10, 2011 | Zebra GX420t Thermal Printer
How to reset IP address on GX430T label printer
http://www.scanonline.com/pdf/PrintersZebra4/GX420t/ProductDocumentation/980612-001A_GX420tUGen.pdf Here is the manual it will tel you how to go about resetting the Ip address on this printer, If its connect to your RJ45 cable or you have a print server you will need to reset it using other means but this should set you on the path to help here, thanks please do not forget to leave a rating.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 03, 2010 | Zebra GX430t Thermal Printer
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Dec 19, 2008 | Zebra 105SL Thermal Label Printer
Zebra GX420t Thermal Printer Logo
75 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
