How to open a return air grille to remove the filter?
I have return air grille in my ceiling. I would like to clean the filter but I cannot get the grille open as it seems to be jammed shut. There is a single knob/screw but I cannot unscrew it; it simply spins. I don't want to pull the knob too hard in case the whole unit comes out of the ceiling.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
It may be a tight fit but just pull on the knob firmly
Posted on May 12, 2014
3 Suggested Answers
philbran
  • 242 Answers
SOURCE: Should I have a return air grill with a filter?
if the closet the inside unit is in is vented to the house the filter should be inside the unit at the top or bottom.
Phil
Posted on Jun 09, 2009
SOURCE: Furnace seems starved for air
Had this problem last year and found that a well meaning painter had put a filter in the return when he had it off to paint the wall. The system had a filter at the furnace intake that was being changed regularly so the homeowner never looked further. If you have multiple returns, check that one is not blocked in some manner. Mainly think back to what has changed in the home since the issue started that might give you a clue. The HVAC system will only blow a certain amount of air and if there was no issue before and it suddenly started its not in the equipment but rather in the air returning to it.
Posted on Dec 31, 2009
Rheem Criteria II furnace filter location
If it's an updraft, filter may be at bottom of unit. Filters are usually installed in the return air side of the system. If you have a return air plenum it may be under a removable plate cover. Also check you return air grill inside your house, filter may be inside this grill,which have opening latches.
Mar 19, 2016 | Filter Heating & Cooling
How do i open air conditioner to clean filters
A wall unit, split system can be tricky to get. Some filters slip out, some are behind a cover held in by screws, others the complete plastic needs be removed. The filter would be in the section where the air enters the air con.
Other units have the filter behind the return air grill, others a door needs be removed to access the filter rack
May 08, 2015 | Heating & Cooling
Trouble locating the air filter in the Goodman heating unit. CAPF036A2A
it will behind return air grille either in the room, ceiling, & i have seen them in attic in return plenum.
Feb 10, 2015 | Goodman Heating & Cooling
Cleaning the filters
Remove the return air grille on the top front of the appliance and you'll see it.
Nov 18, 2013 | Samsung AQV12JAX Heat Pump
I have a Rheem Heat and air unit. Model # RGAC-080AW Serial # CM3D104 F4782 4794 and need to find out where the filter for the unit is located.
What filter are you talking about?
Air filter: Usually with a heat and air unit, the air filter is located behind the return air grill.
Return air grill looks similar to ordinary ceiling or floor grill where the hot or cold air blows into each room. Except the return air grill is larger and is usually put close to the heat-air unit.
Remove the grill and replace filter every 3-6 months.
If no filter is present, then dust and hair get stuck on the coils and unit will not meet temperature setting.
See image of typical air filter:
http://www.instablogsimages.com/images/2009/02/12/air-filter_IYR3W_69.jpg
Jul 30, 2011 | Rheem Water Heaters
Dont know where air filter is located. model # 574ANW030060NA roof top
Most installers will put your filters in the ceiling return air grille. If not, you will more than likely have to get on the roof and remove a side panel. Hopefully it will say "filter access" on the side of the panel.
Apr 09, 2011 | Bryant Heating & Cooling
Where is the filter on my actual unit? Have one in the ceiling is that the only one?
If someone has installed a filter return grill in the ceiling, then thats the only one you will have or need. Even if the original unit has a place for the filter, when an over head filter grill is installed, the installer will not put one in the unit as there is no need. Hope this answered your question and good luck!
Aug 19, 2010 | Carrier 38CKC036 Air Conditioner
Daikin a/c FDY100LVIR N81. installed in suspended ceiling approx 2 mtrs. away from ceiling filter inlet. No filter pad provided for this inlet?. Told to attach a piece of wire to end of unit to withdraw...
Is this a new unit? Lots of units now come with no filter slot. I'm assuming this is above an acoustic tile ceiling. 24x48??? You need to have a 24×24 filter back return grill that lays in the ceiling. That way you change the filter by standing on a ladder. I'm a little confused about the wire thing but, the installer should have thought about how the return air was being filtered BUT, technically not their "responsibility." I'm guessing above the ceiling there is no duct attached to the return side of the unit??? If this were my unit I would buy a filter rack and have it attached to the unit and have my filters the unit. I'm assuming this is a business so what about your fresh air intake?? What filters that??? You need a filter AT THE UNIT. Not attached to a wire or whatever some i*^*t suggested. Hire professionals with credentials capable of doing the job right the first time!
May 26, 2017 | Heating & Cooling
My AC unit is installed today,but right from starting its suction grill i.e the middle portion is not providing any air/coolling effect. Only the side vertical deflectors are blowing air. What could be the...
If it has quick cool on the ceiling assembly, one side slides open & closed, and the larger area is (where your filter is) is for intake air ( return air).
If it is quick cool ceiling assy, try closing off ends by rotating them, then slide grille over (open) & tell me what happens.
Jul 10, 2009 | Heating & Cooling
Phil
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
