Question about Bissell ReadyClean Deep Cleaner
How to fix a Readyclean PowerBrush Deep Cleaner 47B2 that leaks water
Leaks water
  • 294 Answers
SOURCE: I need a manual for a Bisselll 1620 Powersteamer
manuals can be downloaded at the bissell.com under customer care.
Posted on Mar 01, 2009
  • 22 Answers
SOURCE: how to change the belt on a bissell powerbrush
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
Posted on Mar 10, 2009
SOURCE: My bissell Powerbrush cleaner quit working. The
found it from Tara put online in nov 2008 Thanks this is it
Had the same problem... although I don't have particularly hard water, the heater block corroded just enough to stop most of the flow after about 4 years. Disassemble the handle to get at the heater block (3 pairs of screws/bolts), remove the tubes with needle nose pliers, use a paper clip to knock out the corrosion on the front tube on the heater block, flush with a syringe to get rid of any other bits of corrosion (some extra plastic tubing connected to the back tube of the heater block helps here, and catch the water from the front tube to prevent water in the electronics...), reassemble (avoid disconnecting any wires...) and try it out. Worked for me! I REALLY have to thank the person who suggested this fix! THANKS!!!
I used regular pliers , phillips screwdriver , the pointed end of a compass and a turkey baster full of water to blast it out . You have to improvise . Take your time watch the little rubbers on the heater make sure its not hot . It was just the inlet gets pluged up in the heater . You have to take off the tools then its the bottom set of plastic not the handle . You can test by pushing the plunger at the top . You must take the handle off . Loosen the pieces it just came off for me then snaps back on . This is all it was for me , very simple . I am disabled and did it on a extra old carpet a little at a time over a few hours . For someone healthy its a hour job tops or less . Just be patient . God helps those who help themeslves and asks for patience .
Posted on Mar 28, 2009
VacuumRepair
  • 438 Answers
SOURCE: i took my Bissell Powersteamer Powerbrush Deep
Here's a picture of the tubing on the PowerSteamer from an overhead view. I hope this helps you putting the machine back together. I know personally how challenging this repair can be, this picture really was my Bible when I was putting back together the machine for the first time. If you have a question about a particular tube, please feel free to add a comment to the repair page, and I'll be more then happy to answer any follow up question that you may have. If this was helpful to you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner. This is greatly appreciated.
Here's the picture for you:
Chris Jones
GoVacuum.com
Posted on Apr 15, 2010
heatman101
  • 43501 Answers
SOURCE: How to fix Bissell ProHeat 2X 8300 carpet cleaner?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gkjkgj
Posted on Sep 30, 2010
My Euro-Pro leaks steam at the filler cap. It is tightened down but still leaks. Have replaced the rubber ring in the cap but still leaks dangerous pressure steam.
take cap off remove gasket get clr calcium lime rust cleaner put cap in cup of clr give it 4 or 5 min remove rinse replace gasket, empty tank fill with distilled water not tap water no from now on use distilled water only.
Oct 18, 2014 | Vacuums
I have a bissell steam and sweep. when I am finished using it water still leaks from the bottom leaving water?
  • Drain the tank after each use.
  • It either has no shut off valve or a broken one when not in use.
  • If its new return it and see if new one leaks or not.
Nov 13, 2013 | Bissell Steam and Sweep Hard Surface...
Water leaks from the plastic container into the well where the container sits
Locate where the leaks came and then apply epoxy to seal off the hole leaks. When it is done, test the unit in operation and observe if still leaks. If it gone then no more leaks, if it is still there leaks apply again epoxy. Not too much or not too little, just enough to fill the leak hole.
Thanks for asking.
Jul 09, 2011 | Vacuums
My Hoover SteamVac carpet cleaner leaks water
i have a hoover carpet cleaner and when it is not in motion it leaks water
May 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Bissell little green leaks
the tank where the water is has a crack in it mostlikely
Sep 10, 2009 | Bissell 1425 Little Green ProHeat Handheld...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
Oct 20, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hover steam vacume F5864
Is it running out of the bottom of the tank, or at the bottom of the machine. If at the bottom, you have a water line off. If at the bottom of the tank, there is a water seal that the tank sits on, may have to replace that.
Oct 03, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Bissell ReadyClean Deep Cleaner Logo
131 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
