I have machine HP elitebook 6930p. Since a week , its touchpad stopped responding for a minute or so . however after a while, started on its own. however now, its not working ata ll. i am working with an external mouse. any idea, how to fix it
A 2008 built (MFG) PC, Vista is my top guess.(yes?)
sure the cause is only 2 things.
bad software or bad hardware (the classic computer fact !)
so load the drivers from hp.com for your exact PC. there.
if fails
the HW bad, the pad or the cables to it.
in some case the pad may use an internal USB port and that bad.
SW or HW.
also upgrading any old PC, OS to an OS not supported by HP gets you this too, and more. NO OS told no history of OS told.(upgrades)
hp.com is sick today (slug)
https://support.hp.com/gb-en/drivers/selfservice/hp-elitebook-6930p-notebook-pc/3688868
it came with XP or VISTA new, still doing that?
if still that both are infected now, they are virus magnets.
if upgrade to w7, then step 2 is get the drivers for W7, if did.
SOURCE: Disabling the touchpad on HP 530
Go into your windows device manager.
Search for your touchpad (should call synaptics input device)
give it a right click and disable the device.
I rather think that your mainboard is having problems, tried a bios upgrade and the latest drivers yet?
SOURCE: how do you reset the bios on an hp elitebook
Pull the battery, cmos battery, and power cord for 10-20 minutes
SOURCE: hi. i have forgotten the bios pasword and i have
the password stor in bios chip ic is 4*4 legs ....
SOURCE: my hp elitebook 6930p display
I had a similar problem--I had to disable the ambient light sensor to fix the problem: fn-f11. Now it's as bright as I need it to be.
SOURCE: the interner troubleshooter for my
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today. You didn't specify whether or not the WLAN is, in fact off. Can you connect to a wireless connection? If not you can check the following:
On your particular model there may be an array of buttons ABOVE the function keys on the left side of the computer. If not check the function keys themselves. In particular, look at your F12 button. It should have the little antenna logo on it. Press the F12 once. This button toggles the wireless on/off.
If you don't see it, please tell me the version of Windows that came with the computer and the approximate purchase date. Also look at his diagram:
http://h18000.www1.hp.com/products/quickspecs/13061_na/13061_na.pdf
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today. Don't forget to vote. 4 thumbs up please.
