Question about Vibe Portable Bluetooth Speaker Pod
Pairing my vibe portable bluetooth speaker to my phone
I can pair it with my ipod without a password but when i tried with my lg gr500 it required one
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Try pass oooo or 1234
Posted on May 10, 2014
  • Westly Wynn
    Westly Wynn May 10, 2014
    thanks alot bro!
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
How can I change the pin or password on the hmdx rave speaker
go into your settings of phone a see if its saved an delete it then pair again.
May 09, 2015 | Hmdx Rave Portable Rechargeable Bluetooth...
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
How do i pair my phone to play on my insignia speaker?
1. Press and hold the button to put the speaker in "Pairing/Connecting" mode. You should see a red and blue light flashing in rapid succession somewhere on the speaker.
2. Turn on Bluetooth on the phone and tap on Scan. The phone will start scanning for nearby Bluetooth devices. When you see that it detected a device with a name similar to the speaker's name, tap on the name to pair with the phone. If you are asked for a passcode/passkey, enter '0000' or '1234' (without the quotes). If the two pair, the light on the speaker will turn to a steady blue and you will see 'Connect' on the phone. Tap on Connect and then you will see Connected on the phone. Your phone and the speaker are now connected.
The steps above should be detailed in the set up guide that came with the speaker. There may even be a passkey/code provided in the guide. Use that one for pairing instead of the passkey I suggested above. Please note that pairing is a one-time procedure, required only the first time you are connecting the phone to the speaker, a "get to know you" procedure. After that, you just need to connect the two.
Nov 15, 2014 | Insignia NS-BT400 Portable MP3 Speaker w/...
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
Digix BT-100 Portable Bluetooth Wireless Speaker says not connected when I try to pair it with my ipod.
Kathryn,
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired).
Hope this helps!
Nov 07, 2013 | Digix BT-100 Portable Bluetooth Wireless...
What is the bluetooth passcode for an lg gr500 phone so I can send and receive data
Headsets, car kits, and such, have a hardcoded passkey, usually set to '0000' (four zeros).
On the other hand, for pairing between smartphones, computers, and such, the device which starts the pairing process can choose any code the user wants. You could use e.g. the same '0000' from the hardcoded devices, of course, provided that the device you are pairing yours to, specifies the same pairing code.
Hope I have made myself somewhat clear here, since English is not my natural language.
Cheers! Carlos
May 19, 2010 | LG Xenon GR500 Cell Phone
Is there a special setting needed for the LG Xenon GR500 when using a bluetooth?
no just turn on bluetooth pair it with what ever device enter passcode (should be 0000) and let it connect
Apr 19, 2010 | LG Xenon GR500 Cell Phone
Need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Vibe Portable Bluetooth Speaker Pod Logo
405 people viewed this question
Top Vibe Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Vibe Audio Player and Recorder Expert? Answer questions, earn points and help others
