Question about Homelite Garden
What's the correct oil gas ratio to home lite blower mighty 26 bv
It does not start the line to the gas tank was completely deteriorated ,it was replaced it's getting gas to the carburetor just won't crank
Most small equipment is 32:1
4 oz oil to a gallon
8 oz to 2 gallons of fuel
Some Chain saws may be 40:1
Cranking: is a term for a car -- that the starter will not
turn the motor over
You have a no start condition
Got Spark & a new plug
Posted on May 10, 2014
5 Suggested Answers
  • 89 Answers
SOURCE: how to adjust a carburetor on a Mighty Lite
if you take apart the carburator youll see a screen under the plate on one side once together turn the mixture screws in all the way till you feel it seat or tighten then back out each screw 1 to 1 and 1/2 turns then start the engine the key is to get it to idle once it idles turn the mixture screw the low side it will say l or h below the screw turn it in which clockwise till it runs smooth then back out slightly till it just starts to miss then rev up the throttle and adjust the high side which is towards the filter turn the mixture screw in till it revs to the highest point which I call the sweet spot your pretty close to what you need
Posted on Nov 08, 2009
SOURCE: Homelite lite 26 bp blower
50:1 ratio, and any type of two stroke oil will do
Posted on Jun 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: what kind of oil do
2 cycle oil
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 08, 2010
  • 430 Answers
SOURCE: Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Posted on Nov 12, 2012
On a homelite model 26 bv blower Does the gas tank filter connect to anything
The filter fits on the end of the fuel pickup line inside the gas tank. If you see the filter just rolling around in the tank it probably has hardened or damaged fuel lines. Size them up and get replacement lines online or at your local outdoor equipment retailer.
Oct 06, 2014 | Homelite Garden
I do not know the oil-to-gas ratio to mix/buy. My husband passed away, and I cannot find the manual. Help, please. THANK YOU
Can you find the model number on the Homelite Mighty Lite BlowerVac?
For the UT08520 and UT08921 26cc blowers and the UT08550 and UT08951 blower vacs, you can mix the Homelite Premium Exact Lubricant with gasoline following the label directions. For other synthetic oil additives, use 2.6 oz of additive per 1 gallon of gasoline. (It's 20ml to 1 l if you use the metric system.) That's a 50:1 ratio (gasoline to additive).
Many Homelite Blower manuals are available here: http://manuals.homelite.com/documents?page=5 . You should try to find your exact model and then check the manual to confirm that your model blower vac uses this same ratio of oil to gasoline. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Sep 06, 2013 | Homelite Mighty Lite Blowervac
I need a gas tank for homelite mighty lite 26ss. the whole is too big in the gas tank for the gas line.
No, what you really need is the "correct" sized fuel line. Do not alter the hole in any way. Here is an offering for a complete fuel line replacement "kit". I think it is Amazon.com. The sizes of line they have should fit your make and model. See the third Item listed under BLOWERS at the top of the page. Click on that and you will see the item you actually need. Reasonable price too.
http://www.homeliteblowerparts.net/#2
Aug 29, 2011 | Homelite Mighty Lite Lawn Trimmer
How much oil do you use? in the mighty lite
Homelite Mighty Lite engines require the gas/oil ratio to be mixed at 50:1. That is 2.6 ounces of oil per gallon or 1.3 ounces of 2 stroke oil per half gallon of gas. I recommend using synthetic oil. It lubricates much better, allows the engine to run cooler and smokes less.
Apr 05, 2011 | Homelite Mighty Lite Blowervac
I need to know the correct ratio of fuel mix for homelite blower/vac
It is 50:1. That is 2.6 Ounces 2 stroke oil/ US Gallon or 1.3 ounces of oil / 1/2 US Gallon. I recommend synthetic and adding Stabil brand gas stabilizer to the mix. It helps greatly.
Dec 03, 2010 | Homelite Mighty Lite Blowervac
What kind of oil do I mix with gas for my homelite mighty lite bv blower
2 cycle oil
Sep 08, 2010 | Homelite 'Yard Broom' Leaf Blower
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
77 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
