Question about Dryers
We have Atlas copco air Dryer FD 510 A IEC, using Elektronikon II control, dryer runs for a huor and then warning on display appears Phase sequence -CLOSED, tried starting dryer not Starting
  • 18 Answers
SOURCE: Dryer will not start, timer sounds like it is running
Possibly a door switch, or starting switch near timer assembly. it could also be a bad breaker, dryers have a double breaker, even if you are getting electricity to part of your dryer 1 bad breaker might not let the rest of the dryer work. With electrical experiance,and elect. tools, have some one test breakers and plug voltage.
Posted on Apr 08, 2007
  • 1462 Answers
SOURCE: Dryer won't start...
if timer is timing down then it has power so fuse is ok. there is no internal fuse. two things to check if you can hear a low humming noise when drum should be turning, then the motor capacitor is faulty - very common fault and part not dear. no need to get bosch part - you should be able to source locally.to test for this fault, take top off and push the drum. if it starts turning then this confirms the fault check also door catch - this operates an internal switch nand if catch is broken then appliance will not start
Posted on Apr 18, 2007
  • 184 Answers
SOURCE: Maytag Neptune gas dryer beeps.
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Posted on Apr 22, 2008
SOURCE: Dryer clicks when start button pushed but does not start.
A quarter was lodged on the thermal fuse , located below the lint screen on the blower exhaust housing, on our dryer. Remove the front lower panel , 2 screw, and you'll see 2 fuses. I suspect that our control board is burnt.
Posted on Sep 11, 2008
SOURCE: Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Posted on Jun 23, 2009
We want a control panel Part No. 1604 9422 02 Xc2002 for our atlas copco air compressor XAMS 850 CD7. Can you help us on that.
we don't sell parts for anything
contact your atlas copco service center for the parts or get them from e-bay
Sep 20, 2016 | Air Tools & Compressors
I need an operating manual for an atlas copco ZT145 compressor with the elektronikon grapgic plus control panel. I need to change the setpoints.
One of the regional Atlas Copco websites should be able to help or perhaps the mother site.
Just use google.
Feb 17, 2015 | Air Tools & Compressors
Where do I get a spare parts manual for a Atlas Copco xas 160
The staff at www.aircompressordelmarva.com has all the manuals for atlas copco air compressors. You can email or call them. They posted an Adobe link for me for a really large one so I could download it. Very helpful. Delmarva Air Compressor Powered by Network Solutions
Nov 15, 2014 | Air Tools & Compressors
Atlas copco troubleshooting
If pressure on display is higher than set pressure of your safety valve,then your safety valve is doing its job. If pressure on display is lower than set pressure of your safety valve,then your safety valve is defective.
Aug 06, 2014 | Atlas Copco GA Rotary Air Compressor...
Always exhausting through auto dumps
Depending on type will require replacement. Usually dirt becomes lodged in needle valve assembly so can have go at cleaning.
Mar 31, 2014 | Atlas Copco 15hp Rotary Screw Air...
Cfgf 3 fault on display atlas copco GA 45
alternately flashing messages [CF GF] and [3] - this is Electronicon Controller software error - probably the controller memory has been erased by a short circuit or something similar, sorry for the bad news
Jan 28, 2014 | Atlas Translator Atlas Copco Air Hammer...
I have zt18 atlas copco compressor, problem is, there is too much water in filters, but the air drier are ok..
Inexperianced installers have a way of putting very fine filters ( which cost a lot to replace the elements ) in a position where they will quickly block with moisture. The normal way of installing final fine filtration is at the very end of the out going air line before using the air. The flow diagram should be air compressor, intercooler, air reciever or tank, air dryer, final filtration then air supply. We have the same issue as you, wet filters. another problem could be the condensate from the air dryers is not being expeld from the air dryer enough to stop the condensate building up. Some dessicant type filter. have a shuttle valve that allows the condesate to be expelled. Our dessicant filter shuttle valves broke not long after installation of the compressors and required a retrofit to repair.
Aug 07, 2012 | Air Tools & Compressors
I have Atlascopco Air compressor GA55+. Now it has a problem in its display unit. Its Part no is 1900 0701 05. It is not responding any funtion and just display 1000300000000. Please suggest me what is the...
you have a bad controller. you can have it replaced or and Atlas Copco tech may be able to program it. If not your only option is to replace the controller.
Aug 26, 2011 | Air Tools & Compressors
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Compressor is loading without unloading
hi mate it could iver be a faulty load solenoid valve or the unloader its self is jaming up inside which means you have to strip it away from the air end and replace all the seals inside or give it to a specialst we are compressed air engineers we could sort it i will leave you a number call us anytime 07958354730 or call 01752 848801 many thanks
Jun 08, 2008 | Kano Technologies Atlas (K752HCDR) DVD+R...
Dryers Logo
142 people viewed this question
Top Dryers Experts
