Question about Sewing Machines
Have thread caught up top in Machine and wont work Is there a way to open top up to Clear Have a janome 350 e
  • 3 Answers
Well..for a start, check out this video. Then you can narrow down on your problem from this link..
Posted on May 10, 2014
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
  • 240 Answers
SOURCE: top thread breaking during sewing.
Your top tension may be too tight or it could be incorrectly threaded. Check threading and ensure you are using a good quality thread. Cheap threads breaks without a reason!
Posted on Jun 11, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
SOURCE: The top thread gets caught in the shuttle hook and
I am having same problem
Posted on Sep 27, 2009
SOURCE: How to thread sewing machine Janome model 372
how to thread a janome model 372
Posted on Dec 27, 2009
Top thread keeps breaking
These are some causes. The thread guide has been missed so re-thread the machine. Tension is too tight. Needle is blunt or bent. Thread is getting caught on the rough edge of the spool so turn spool around. Hope this helps
Mar 09, 2014 | Janome 1600P-DB Mechanical Sewing Machine
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
The machine thread keeps breaking
try rethreading the machine
the top thread tension might be to tight
needle may not be inserted into needle clamp correctly
thread could be caught on something like--spool pin--notch on spool
needle may be damaged
Oct 08, 2010 | Janome Sewing Machines
The top thread on my Janome 300E is getting caught in the bobbin. It starts bunching up on the back of the fabric that I am trying to embroider and it gets stuck. When I pull it off all the top thread is...
If your thread is getting caught underneath it's usually the UPPER thread is threaded wrong or not correctly through the tension discs. This can also happen if you're using Sticky Back stabilizer. Make sure you have a new needle in case there's a burr on the old one which can also cause this problem.
Aug 22, 2010 | Janome Memory Craft 3000
The top thread is pulling very tight. The bottom thread is fine.
sometimes the thread can get wrapped around the spool pin
& sometimes the notch thats on the spool the thread can get caught on it also
try rethreading the machine again
Aug 13, 2010 | Janome Sewing Machines
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Thread getting caught
make checks on the bobbin case that holds the bobbin beneath the machine it could be broken or too tight then you need to slacken it a bit so that thread can flow easy there after oil your oil the machine if the bobbin case lever is broken or bent replace it.also adjust tension disc.good luck.
Mar 26, 2007 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
