Question about Coleman Mobile Modular Home Electric Furnace Eb15 Eb15c
Why is the blower relay sparking when fan starts
Blower doesn't stop running when auto kicks off and sparks fly every time i start it back
    Genius:
  • Coleman Master
  • 1,363 Answers
Contacts going bad in relay
Posted on Aug 20, 2015
4 Suggested Answers
manhandy
  • 146 Answers
SOURCE: If fan is manually started, a/c works ok. Will not start on own
it looks like getting power. if starts up manually then it could be Capacitor which get the fan going or the fan motor it self. i can tell you the Capacitor is much cheaper! i would start with that first
Posted on Jul 06, 2009
qasolution
  • 107 Answers
SOURCE: coleman mach ac blower stopped
bad motor windings.replace the motor
Posted on May 07, 2012
hvac1960
  • 2133 Answers
SOURCE: AC UNIT RUNS AND ALL OF THE SUDDEN FAN STOPS AND COMPRESSOR WILL RUN A LITTLE WHILE AND STOP. THEN FAN STARTS AND COMPRESSOR KICKS IN AS NORMAL. ONLY HAPPENED A FEW TIMES, BUT I DONT WANT TO WAIT UNT
Check the condensor unit. May be dusty. Clean it. If still problem replace capacitor.
Posted on Sep 07, 2012
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Armstrong ultra advantage 93, propane. blower kicks on right away when i call for heat via thermostat. will not ignite. blower keeps running. fan set to auto. help!
Make sure that there is not a manual limit that has tripped and needs to be reset. Roll out limits, and check primary limit. On some models if a limit is tripped the blower starts to run right away.
I don't know if this will fix it. But that is where I would start if I was working on this problem. Then I would check if the combustion blower starts and then if it makes the pressure switch. Then check if the ignitor is sparking or glowing and getting power to it. A good volt meter will help in checking.
Good Luck.
Oct 26, 2013 | Honeywell Furnace Air Pressure Switch...
I HAVE A 1996 TOYOTA COROLLA., THE INTIERIOR FAN IS NOT WORKING
It doesn't sound like a fuse problem to me. More like the blower motor is bad. Try tapping the blower motor with the back of a screwdriver next time it starts acting up. If the fan speeds up or starts up, definitely a bad blower motor.
Feb 09, 2013 | Motorsports
Having multiple intermittent problems
I guess the overall answer is yes it could be the ECM.
Code 16 is high or low system battery voltage.
Code 21 and 22 are both for the throttle position sensor.
And code 43 is for the electronic spark control which controls engine spark timing.
The ECM grounds various relays to make things happen such as turning on the cooling fan. So a faulty ECM could cause all of the symptoms. But so could a wiring problem in one of the harnesses.
Especially a ground problem somewhere.
If the alternator suddenly starts overcharging the system the ECM can shut down the car to protect the circuits. Unusual, but possible.
This info may not help much, but somebody is going to have to test the circuits when the engine dies or when the symptoms happen.
Jul 11, 2012 | Cars & Trucks
Replaced timing belt engine will not start
check for spark at the sparkplugs, and listen to hear the fuel pump going when key is turned on. if no pump noise and no spark it can be the auto shutdown relay located on the drivers side fender behind battery. the auto shut down shuts off power to the ignition and fuel pump if the timing belt snaps. ,,,, if you have spark and fuel pump works then check firing order on plug wires , if they are in right place then check timing , if timing belt was replaced without lining up the timing marks it wont run
Dec 31, 2010 | 1995 Plymouth Voyager
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Won't start, no spark and fuel pump wont run
This could be one of two things. One of which is the ASD Relay or Auto Shut Down relay. The is the ignition relay. Both of these are located under the hood.
Sep 15, 2008 | 1994 Plymouth Voyager
Coleman Mobile Modular Home Electric Furnace Eb15 Eb15c Logo
61 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
