Question about Samsung Galaxy Tab on 3 Mobile Tablet PC
How do I connect to WiFii - Samsung Galaxy Tab on 3 Mobile Tablet PC
    Problem Solver:
  • 16 Answers
I found it here: http://www.samsung.com/us/support/howtoguide/N0000408/11374/133461/GT-P5210GNYXAR Connecting to the Internet
  1. Power the device Off then On.
  2. Connect to your Wi-Fi network.
    1. Tap the Home Key, and then tap the apps button.
    2. Tap Settings, and then tap Wi-Fi.
      • If Wi-Fi is off, slide the slider to the on position (the slider will be green). The tablet will scan for wireless networks automatically. You can also tap the scan button.
        Note: Verify Flight mode is turned off, if flight mode is on you cannot connect to a network.
  1. The device lists the Wi-Fi networks in range.
    • If a Wi-Fi network appears but is not familiar stop here, and then verify the settings on your AP/Router.
      1. Make sure your AP/Router is operational by performing a soft rest. (Turn the AP/Router Off and then On again)
      2. Make sure the AP/Router is transmitting the network SSID or Manually add a network if you don't want to broadcast your network SSID)
  2. If no Wi-Fi networks appear and you're certain that your network is in range stop here, and then verify the settings on your AP/Router.
  3. If your Wi-Fi network appears, tap to select your network, if Security is enabled enter the Password for your network, and then tap Connect.
Posted on May 10, 2014
Why doesn't my digiland tablet connect to the internet at work. The wifi info says it's connected and excellent! Works fine at home. I also use a Nook Tablet and it connects fine!
Usually with 'work wifi', or any public hotspot, merely connected isn't enough. You have to open your browser and connect to a new page. It has to be something that isn't in history or cache. I favour ba.com because it is short. Accept the Terms and Conditions and click Connect. Once the page refreshes, you are connected.
At home, you are connecting to your own internet and not through a third party company like Datavalet, Boingo or similar. There is no terms and conditions to accept, so you are immediately connected.
Feb 14, 2016 | nook tablet Tablets & eReaders
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
You can try this and see if it works for you:
Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
  1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
  2. Under "Wireless & networks," touch Wi-Fi.
  3. Touch the Wi-Fi switch to turn it to the On position.
  4. You'll see a list of saved and available networks.
    • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
    • Your device will remember networks it connects to and automatically connect to them when in range.
    • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
  5. Touch a network name from the list of available networks to connect to it.
    • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
  6. Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Nov 11, 2014 | Tablets & eReaders
Why is my tablet not connected in a networ but it is already connected?
It may be connected to the Internet, but not connected to any local (home or public) network.
Jun 28, 2014 | Tablets & eReaders
Website says 'bad connection' but I've been on it numurous times
Have you checked and made sure your Wifi is connected and you have a good connection? If you see your wifi is connected, one way to check if you have a good connection is by running speedtest.net app (can be downloaded from app store). With it, you can determine your current download/upload speed. If you barely have connection, it'll show a very low speed and thus why you get that 'bad connection" issue. Hope this helps
Apr 13, 2014 | Samsung Galaxy Tab 2
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
I had bought an ipad wifii and a new mtnl wifii connection last week. My mac could connect to the wifii network seamlessly, but am facing problems with ipad connectivity. Ipad could connect with the...
there were some random wifi issues with ipads early on but the most recent updates through itunes have corrected those. So best thing would be to connect to your computer and make sure its updated. if that doesn't work, may be a range issue, they dont have the longest reception.
Mar 31, 2011 | Apple iPad 64 GB 3G Tablet PC
My new tablet will not connect to internet. i have the usb plugged into mt laptop. i do not have a wireless router?
open network connections on your laptop and select both the wireless adapter AND the internet connection adapter in there and right click on them and click bridge connections. Then go into the network setup wizard (XP) or network and sharing center and click connect to a network and choose adhoc connection. then open wireless settings on the coby kyros and connect to the adhoc connection on your laptop. You should then be able to connect to the internet on it
Mar 26, 2011 | Coby Kyros 716829701508 Tablet PC
My fujitsu lifebook t4215 will not connect to the internet. When I check the connection, it says that it is connected, but when I try to bring up Internet pages, it won't bring any up.
So you're connecting with WiFi eh? I take it you've already disconnected and reconnected with no progress?
Next would be to shut it down, and reboot. Try it again.
Are you connecting through a router? You might be "connected" to the router/hub but it may not be actually connected to the internet. Can anything else you have or someone else connect to the internet through the same connection? If so then we know the connection is good, and it's the Lifebook.
Look for "NETWORK AND SHARING CENTER" and see what that looks like. It should show you a graphic of the connection and you may find it as I described above. You need to eliminate or identify your condition at this point.
Good luck!!!
8^)
Jan 04, 2011 | Fujitsu LifeBook T4215 Tablet PC
Samsung Galaxy Tab on 3 Mobile Tablet PC Logo
41 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
